- Oct 20, 2012
- Thread Starter
- #21
Did you physically set the values back to default or did you select the bios option to reset all to default? Make sure you go into the bios and use the "set all to default," or whatever that is for your motherboard, and then see if it still BSOD's.
If it still crashes then you might want to run memtest86 on each of your memory sticks individually to test for errors. One run each should be enough to rule them out.
Yes, I reset all settings in my BIOS to default, and even did the same for my Graphics Card...And still, it keeps BSOD'ing with 0x00000101...
