temp trouble
Seanie's Show im running your first lot of settings and im finding some problems with heat, also at 200 bclk im getting 4.2ghz is that correct? my temps are getting upto 92c before i bottle and stop the prime95 small fft test.
im running an ek wave 775 block which ive moddified to fit the 1366. the rest of the loop is as follows:
eheim 1250 pump
thermochill HE120.2
2x panaflo 120mm fans 7v modded
ek full cover block on 8800gts 512mb
120mm fan blowing over the mosfets, northbridge, and memory
psu corsair 750w hx
cpu i7 920 D0
ram 6gb gskill PI 1600 cl6, im using the xmp profile
i thought maybe my rad wasnt upto the job, but the gpu temp is around 46c when idle, with the cpu 100% load and 85c+. could it be the ek wave isnt upto the job?
eheim 1250 pump
thermochill HE120.2
psu corsair 750w hx
cpu i7 920 D0
