well i pulled out my old ge force 3 ti200 recently and had a look at it, it has this ****ty little heatsink on it( i think a coulple of ramsinks w/ no fan would do better than this and it has a fan!)
and wanted to oc it.
well after a while i decided to grab a couple of ramsinks and a copper 1u heatsink(cool jag jac317c) and mounted a 60x60x38mm delta screamer on it. which is definately overkill but this setup is eventually gonna be transfered to my next card whenever i get it.
the HS is attached with as epoxy, the ramsinks with 3M thermal tape and the fan is at 7v(i would go deaf if it was at 12v) now all i need to do is oc the thing and see how far it will go
now i would put up some pics but i dont know how to resize my pics from 4000+x6000+(5megapixel camera) without using photoshop.
are there any programs i could use to resize them?
thx
BTW this is my first mod/project i hope i can goe a decent oc outta this thing!
thx
