- Nov 15, 2012
i did a fresh install of windows 7 64bit for my friend. Has a Nvidia GeForce 8800 gts. the card is running at full blast constantly . i already went down the driver route and that is pretty much ruled out. all drivers are good. the fan is really annoying . any one have any suggestions to fix this problem.? thanks in advance
-also thought it was important to note whenever i reinstall the latest driver at one point during the download the resolution goes to the smallest setting while it downloads and the gpu calms down to normal levels then the install finishes up and goes back to the regular 1080p resolution and back to100% load
- weirdly enough only the GPu memory clock shows being 100% while the gpu clock sits at 0%
some specs
500 watt PSU
amd phenom 2 940BE
geforce 8800 gts
Windows 7 64 bit premium
4 gigs ddr2 ram
m2n32 deluxe asus mobo
some specs
500 watt PSU
amd phenom 2 940BE
geforce 8800 gts
4 gigs ddr2 ram
