- Aug 5, 2002
nikhsub1 said:I have had absolutely NO ISSUE with drivers at all! I'm running 64 bit too. Right after the install I looked in device manager and guess what? Every item had a driver! The only drivers I added were the proper vid driver and the intel chipset driver. That's it. The docs folder is not an issue for me anyway, I keep the my documents on a different HD, always have. Same in vista. I told it where my docs should be located and bam it was done. I think made a shortcut to my docs on the desktop.
Ram usage you say? This is the NUMBER ONE misconception about vista. While I'm sure it does take a bit more ram, the thing that people (most people) dont realize is that vista is MUCH BETTER at ram management and allocation than XP ever could be. This goes back to what I was saying about it feeling 'snappy'. You see Vista caches lots of things in RAM, this is part of superfetch (which rocks BTW). Even with 4GB of ram when you go to task manager you will find you don't have much free ram - here lies the catch; you do! Vista will release this cache memory instantly as soon as it is more directly needed - say photoshop or rendering etc, etc. If you are familiar with any DC project like Folding@home or SETI then you will understand this concept. These DC projects use all UNUSED CPU power - that is if the system is at idle FAH or SETI will use 100% of the CPU. Now say you start rendering or any CPU intensive task then these will instantly release the CPU power that is needed. This is precisely how Vista manages memory.
Indeed, theres very few programs I have true issues with, zero driver issues. Sure it uses more ram idling but from 1gig to 4gig (similar systems mind you) at least it keeps in mind what to use and what not to use. Heck my system has from 3-4gig (depending on 32 or 64-bit mode) and it uses up on boot from 850-1100Megs of ram (varries with the amount of ram seen). As well with a 1gig system it uses under 600Megs on load with everything turned on. IMO great memory management.
As well one of my biggest favorites is the Graphic Driver revision. Where it seperates what programs have for memory allocation and locks it in there saying it has that so no other program swaps over and trys using it. As well if the video driver or program crashes most likely it won't need a reboot because of the video drivers and how it interacts with the DX system. I can't tell you how many times I've had games crash and it needs a reboot, this at least will let me cancel the game out or at vary least go to the desktop and save anything needed prior to closing it. Some programs its a 50/50 deal though if it will hang the system though but then again so far its only professional programs that aren't certified for Vista at the time.
Anyways main topic, another company decides nto to join in. Its just like the DOT, FAA, and other agencies that won't til SP1 comes out, and was the same way with XP as well. Can only hope that it goes smoothly and they add in more features that where taken out for the release of Vista. Overall experance much much better then when switchin to XP from 2k. Sure it has some quirks but it hasn't affected my overall system usage in the last 6 months that I've been using it at home. If you don't need it don't upgrade (main reason is DX10), if you want it upgrade, if your undecided surely MS will release one of those trails eventually or try out some of the desktops/laptops at your local stores to get a feel for it.
