OK, it's been more than 20 years since I OC'd my PC. Back then things seemed simpler. There were fewer options to change, etc. Your clock multiplier was locked unless you spent insane money or modded your CPU. Anyway, I digress. I'm looking for help or guidance and I just don't want to let the magic smoke out. I've looked for OC guides for the motherboard I have but they all use the Old GUI from Gigabyte, so I get lost trying to work with the new interface and finding all the options they are referring to.
Any help is appreciated. I'm especially looking for what I should consider my max Vcore (safely), what power and other auto options in the BIOS I should turn off. I'm planning to use this primarily as a gaming rig. Hence the 3 1440p monitors. Thanks in advance for your help.
Here is what I have:
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor
CPU Cooler: EK-Kit P360 (EK Waterblocks P360 performance custom water cooling loop kit)
Motherboard: Gigabyte Z390 AORUS ULTRA ATX LGA1151 Motherboard
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive
Storage: Seagate Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB FTW3 ULTRA+ Video Card
Case: Phanteks Enthoo Pro Tempered Glass ATX Full Tower Case
Power Supply: EVGA SuperNOVA P2 850 W 80+ Platinum Certified Fully Modular ATX Power Supply
Optical Drive: HP 1270i DVD/CD Writer
Monitor: VIOTEK GFT27DB 27.0" 2560x1440 144 Hz Monitor
