changing the fan speed doesnt void the warranty does it?
and what if I'd oc the card from catalyst control, would that void the warranty?
Just wanted to say my Asus card came with a program called SmartDoctor which auto-throttles the fan speed based on temperatures you decide, I think that this program would work on other cards.
The program is called SmartDoctor, you can find it on the Asus website if you poke around a bit, and it does let you set overclocks but not profiles like the ATI CCC.
You have to disable your profiles in CCC to get it to work I think, I had to click defaults on CCC and then click through the options in smartdoctor to make sure it was on the right setting.
did this and it's working, thanks guys !
<Feature name="FanSpeedProtocol_0">
<Property name="FanSpeedProtocolProperty" value="Percent" />
</Feature>
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="50" />
</Feature>
</Group>
<Feature name="FanSpeedProtocol_1">
</Feature>
<Feature name="FanSpeedAlgorithm_1">
</Feature>
<Feature name="FanSpeedRPMTarget_1">
</Feature>
<Feature name="FanSpeedPercentTarget_1">
</Feature>
</Group>
<Profile>
<Caste name="Graphics">
<Groups>
<Group name="Overdrive5">
<Feature name="TimeUnlocked" />
<Feature name="OverclockEnabled">
<Property name="OverclockEnabledProperty" value="True" />
</Feature>
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="50000" />
<Property name="Want_1" value="50000" />
<Property name="Want_2" value="62500" />
</Feature>
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="75000" />
<Property name="Want_1" value="75000" />
<Property name="Want_2" value="99300" />
</Feature>
<Feature name="CoreVoltageTarget_0">
<Property name="Want_0" value="1046" />
<Property name="Want_1" value="1046" />
<Property name="Want_2" value="1123" />
</Feature>
<Feature name="MemoryVoltageTarget_0">
<Property name="Want_0" value="0" />
<Property name="Want_1" value="0" />
<Property name="Want_2" value="0" />
</Feature>
</Feature>
</Feature>
</Feature>
<Property name="Want" value="30" />
</Feature>
<Feature name="CoreClockTarget_1">
<Property name="Want_2" value="65000" />
</Feature>
<Feature name="MemoryClockTarget_1">
<Property name="Want_2" value="105000" />
</Feature>
<Feature name="CoreVoltageTarget_1">
</Feature>
<Feature name="MemoryVoltageTarget_1">
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Group>
</Groups>
<Adapter name="PCI_VEN_1002&DEV_9442&SUBSYS_05021002&REV_00_4&302BF57C&0&0008A">
<Aspect name="Overdrive5" />
</Adapter>
</Caste>
</Profile>
