- Jan 29, 2007
Hi guys, I have heat issues with the i9. I have tried multiple things, but nothing seems to be helping.
Room temperature without AC 30C. At night I can run 30% CPUs and 40% of the time on Bonic. But sometimes in the morning I still see some 80C max temps on HWmonitor.
Daytime with A/C room temp somewhere around 26-28C I run 70% CPU and 70% of the time on Boinc, but I am still hitting 80C.
What I have done:
Case FSP - 4 120mm original LED fans
1x rear exhaust fan
3x front intake fans
MSI Torex 120mm Fans 3x
2x exhuast roof
1x rigged to top of HDD case below GPU removing bottom case heat
CPU - cooler master 120mm
2x fans push/pull
1x Noctua NF-A14 PWM 140mm
This fan is rigged with twist ties hanging from the roof angled downwards into the intake cpu fan to bring cooler air from outside the case through the top inwards.
This setup has created the best temperature scenario so far.
In addition I have removed the back right panel behind the MB, but on all intake air places I have put up a 3M filter to keep the dust and cat hair out of the system. There is still massive amounts of air being pulled into the system. The Noctua fan pulls air from the top and the MSI fan pulls air from the bottom.
Additionally I pulled back the roof magnetic screen away from the rear roof fan to allow more hot air to escape without obstruction, it helps.
As this system is new and having consulted many people before buying I opted not to install a water cooler. And looking at info online I am not 100% convinced that a water cooler would significantly reduce the temps or not. And frankly at this point I don't want to fork out another $250 for a cooling system.
I have not checked the thermal resin, as the system is new and even though the installer is a jerk, I believe it should be ok. I am not calling him to check it, I will end up waiting a month anyway. And if I ask someone else to redo it their is more cost involved. anyway..
So the purpose of my post here is to see if there is something else I am missing, forgot to do, something else I can do, a better way to rig the fans, like reversing one of the roof exhaust fans to blow into the cooler instead? I don't know. I did have a Noctua 3000RPM industrial fan installed last week, but it was way too loud, but it worked better, it kept temps below 80. But it is way too loud.
I am considering to knock down my CPU speed and voltage in order to bring down temps, but I am not sure how to do it while keeping things stable with or without using Bonic.
Screen shot attached is current temps. 70% cpu at 70% of the time, with AC on.View attachment 210064
What I have done:
1x rear exhaust fan
2x exhuast roof
2x fans push/pull
