Okay were shall we start? first up, if this thread is in the wrong forum area then by all means move it, cheers.
For about the last 4 months or more my computer just randomaly reboots, about twice a day, so I went into the system properties and to the advanced tab>startup and recovery>settings>system failure and unchecked automatically restart, now every time my computer restarts it comes up with a blue screen instead of just rebooting, the usual page of white text etc, at the bottom it says system stop then lots of numbers etc.
My system is overclocked to an fsb of 152, multiplier of 12.5 vcore of 1.825 it has been running that for about 2 months now, passes prime and hot cpu tester in burn in mode. I set all this back to default to see if that was the problem, no go, So next I thought I'd check my ram, I have 2x512mb elixir ddr333 (PC2700) dimm modules, I have them running at PC2100 at about 303 mhz ddr ofcourse they pass memtest86 which was run for hours and hours, then i thought it might be my PSU, which is a cheap yum cha branded 300watt, so i went out and brought a new thermaltake 420watt model, put this in a few days ago, it still has the problem, kinda ****ed because that PSU cost me $139.00AU, but atleast now I have a good PSU. I even tryed a different bios, no go. I also tryed running different ram timmings, my motherboard is very limited.
I have a prolink pixelview Ti4200, lapped core, ram sinks, amd cooloer, I thought this was the problem, so i set her back to default and still no luck, i even tryed different det versions
My specs are as follows:
8K5A2+ motherboard running the latest bios.
RAM, 2x 512mb ddr333 (PC2700) elixir modules, nanya chips, see pics below.
My cpu is AN XP 2000+ default speed of about 1667mhz, not ovreclocked at the moment:
AX2000MT3C
AGOIA 0209 TPAW
Y7882436947
© 1999 AMD
i use a Swiftech MCX462+ with a 80mm to 120mm adapter and a sunnon 120mm fan running at full speed (avout 105cfm) plus 6 case fans, the average temp not overclocked is about 32c at the moment.
My PSU volts are at: 3.3v is at 3.39, 5.0v is at 5.05 and the 12.00 volt is at 12.43, they are all rock stable (anyway it's not the psu, as stated above)
I am using windows XP pro, 45.33det's, direct x 9.0a latest via drivers.
I personally think its my ram, need any more info just ask.
Cheers
AX2000MT3C
AGOIA 0209 TPAW
Y7882436947
© 1999 AMD
Cheers
