- Jun 27, 2002
- Toronto, ON, Canada
hi ppl, i bought this geforce3 a while ago, im satisfied how it performs at stock speeds but i still want to oc it a little so i can keep it until nv30 is cheap enough ...
Well, the ramsinks were in it already when i got it, but i need some help to take them out safely and use artic silver epoxy instead or eaither AS3 along with superglue to get lower temps (more likely to use this last method). Same goes for the heatsink/fan so i can replace it with a cooljag with also AS3/superglue.
And as a final thought, would it be a good idea to cut the ramsinks in pieces to make an individual heatsink for each of the 8 ram chips??? or will it cool itself more effectively the way it is right now???
Thnx for your time and help
