- Aug 9, 2012
- Toronto - Canada
Hi everyone, and thanks again for looking into my tread.
Im back to building a new pc after 4 long years from hiding behind the rock.
Long story short - Im looking to build a Mid high end PC with a i3570k
Purpose : Mostly BF3 gaming - Tons of surfing + online streaming movies
Budget : None as long as its within 100 dollars of the item im about to point out
Items needed : cpu - motherboard - SSD - Ram
Items that I already have:
Galaxy MDT GTX 580
Antec Truepower Trio 650W ( http://www.antec.com/specs/TP3_650_spe.html )
Antec Nine Hundred Black Steel ATX Mid Tower
Things dont needed : CD/DVD ROM (will install wins7 via USB
I will only use 1 SSD of 240G (i dont save movie/music to my pc)
I will not SLI/CROSSFIRE
Ive never OC before and i would like to in my 3570k since people say its easy, so CPU is decided already - please post a item part # of a good Air cooler.
at this point, the max OC i would do is 4.2 ... but 4.0 would do too (i want the OC speed to be permanent, not like others that OC to 4.8 just for games then back to 4something for surfing, etc)
MOtherboard - Im totally noob at this, I've heard MSI Z77A-GD65 is very good and OC genie would do all the work for me? i read a little bit about that mobo and seems pretty good .. any other input from you guys? gigabyte? asus?
SSD - i also read a little bit about it and i think i would go for intel 520 240G
since its fast and reliable? or should i get the samg 830? vertex 4?
Ram - im debating either 8G or 16G . mostlikely 16G
again, i would like reliability so im gonna choose kingston, but i want it to be fast too ! .. as for now i have this in mind "Kingston KHX2133C11D3K4/16GX 16GB 2133MHZ DDR3 NON-ECC CL11 DIMM (Kit of 4) XMP"
should i stick to 1600 for the ram? will the 2133 make a huge diff?
also im open to a diff opinions such the G.SKILL Ripjaws, Corsair , Mushkin.
Thats for all ... Please help
so in mind i have:
i5 3570k - MSI Z77A-GD65 - Intel 520 240G SSD - Kingston KHX2133C11D3K4
(waiting for your input for a good air cooler)
- please post your answer and explain why if possible - also ask me any other info if needed. and again, just post the item part # or model and i will find it myself either ncix, newegg , etc
Galaxy MDT GTX 580
so in mind i have:
