Sounds like your refresh rate to me, at 60Hz you will notice this but usually anyuthing higher is fine. Go into you display settings in the control panel and go to the advanced section and under the MONITOR tab you should see refresh rate. Set it to something higher than 60, BUT make sure your monitor can handle high refresh rates, if its a fairly new one you should be fine. Older monitors sometimes don't like high refresh rates.
