- Dec 30, 2003
Hi,
Im fairly new to OC and would like some help on where to start.
My computer specs are:
850 mhz Tbird model C (unlocked)
Asus A7V classic Via Apollo KT133 Chipset
256 megs of 133mhz sdram
geforce 2
SB live
Full tower
300w
2cd drives
I built this computer a few years ago, but since its getting old. I would like to get the most i can out of it. I am new to OC but i think i know enough to get the job done.
I OC it to 895 mhz by changing the FSB only and would like help with what multiplier/fsb is best to start with.
My current setting is
895MHz: 8.5x Multiplier, 105MHz FSB, 140MHz DRAM
My I/O Voltage setting is default at 3.56
and my Vcore is default at 1.75
I belive my cpu temp is around 30 or 40c
I also read that having a higher FSB is better because it will allow more bandwitdth. i.e.
105x9.5 > 100x10 is that true?
When should i up my I/O voltage?
My goal is to reach 1000mhz or higher
So any tips or suggestions would be helpfull!
Thanks
geforce 2
SB live
Full tower
300w
2cd drives
Thanks
