- Jul 15, 2007
- St. Clair Shores, Michigan
My computer has been touchy for about the last year and half and I'm not sure how to diagnose the problem. It freezes at sporadic intervals and is not just limited to CPU/GPU intensive tasks. For example, one time it could freeze during starcraft 2, but then other times while just listening to music or browsing the internet. Sometimes it happens multiple times in a day, but then other times goes multiple weeks without a problem.
Things I've tried:
Ran prime95 overnight
-Max temps, 55C CPU
-No crashes
Ran memtest overnight
-No errors
Used FrozenCPUs PSU tester
-All good
Used multimeter to check all PSU connectors/pins
-Voltages well within +- 5% tolerance
Various benchmark testing programs
-Temperature levels fine throughout
-Multiple times ran, never crashed
Grabbed a Kill-a-watt meter
-My PSU is a 650W corsair HX model, max pull was 370W on kill-a-watt
New optical drive (DVD/CD combo drive installed)
All old hard drives removed, one new SSD drive installed
Reformatted and only have basic applications/games/drivers installed
I'm out of things to try, but this problem still occurs randomly. Does anyone have any ideas/tests that I could try? I'm trying to decide whether a not a new PC is worth it or if this problem can be diagnosed. My current PC is powerful enough for the games I play, but if this problem ends up being something faulty with something such as the motherboard, I'll put money towards a new computer. My current rig is listed below.
Current setup:
Evga 780i SLI motherboard
Intel q9450 CPU, stock @2.6ghz, oc'd to 2.8ghz
G.Skill (2x 2GB) DDR2 1066 memory
Evga 8800GTX @ stock
1x combo DVD/CD drive
1x SSD - main drive running everything
1x HDD - Backup SATA drive that usually is kept unplugged
ASUS xonar essence ST audio card
Corsair 650W HX power supply
Thanks for any suggestions
Things I've tried:
-Max temps, 55C CPU
-No crashes
-No errors
-All good
Current setup:
