X18 vcore 1.35 @ 3.60
Ok cool, I'm going to bed now, I will check in when I get up and see how you got on .
If necessary to accommodate tall heat sinks, the fan on the Coolermaster Hyper 212 can be positioned a little higher on the heat sink face. The fan is held on with plastic clips on each side that hug the heat sink. Just clip it on a little higher. The other question of importance with regard to the CM Hyper 212 is will there be enough clearance to the side panel to be able to put the side panel on. That cooler is about 160mm tall. Most cases at least 7.5" wide will provide the necessary clearance.
i will measure it and see , I will measure how much room i have from the Motherboard and out words
But what you are saying is that You also Recommend the CM Hyper 212 Right ??
QUOTE]
As long as it fits your case you can't go wrong for $30
Thank you
Great thank you , you mean an extra fan for backup ?? or i can put 2 fans on it ??
Forgive me i am new hhhhhhhhh
