- Dec 27, 2008
Thanks to all For the fast reply you Guys are great
Just a Fast Question will it hurt if i leave the Voltage at AUTO ?? it seems it runs smoother and at what number should i start ?
It won't hurt anything it's just that you can't expect to progress in your overclock unless you increase the voltage to your CPU. The higher voltage becomes necessary to support the higher frequency in order to overcome the resistance to the flow of data (electrons) though the silicone circuits.
