Alright, I'll explain a few simple specs about my computer system and the problems I'm encountering.
Asus P4P800-E Deluxe motherboard (sock 478)
Intel P4 - 2.4GHz Prescott
Sapphire Radeon 9600 Atlantis with 256 MB of RAM (AGP)
1GB (2 x 512MB) DDR400 Kingston HyperX system RAM
Right now I've been experiencing a few problems that I've deduced to being my AGP video card. Random artifacting had begun but was never too severe. When I attempt to load up my Lineage 2 (MMO) client the system would do 1 of 2 things: 1) Restart, or 2) Monitor would say "No input detected" and turn off but with the system still running. In other words, I go blind but I can still hear my MP3 playlist blaring.
I've updated my entire systems drivers, including the newest drivers for my video card. This only increased the occurences of the problems. I then installed the ATi Catalyst Control Center to see if it had any tools of use to me. The first two times after installing it and testing different driver versions for my card the CCC would attempt to "Automatically configure system settings for optimal performance" and problem #2 would arise (see above for problems 1 and 2).
Once that ordeal was finally over and the CCC no longer attempted to maximize my graphics performance after a system reboot I avoided my game client for some time. Eventually after 45m-2hrs of surfing the net I would once again encounter problem #2. It seemed that the random system restarts (problem #1) had ceased.
Then I began playing with a few settings in the Catalyst Control Center. I found the setting for "VPU Recover" which would reset the VPU in the event of it not responding to the display driver. About 10 minutes after applying this setting, my monitor acted as if it were lapsing into problem #2, however the black screen was restored and the CCC brought up the display message saying the VPU Recover had reset my VPU (as it should) and disabled my Graphics Accelerator.
Since then my system has not been doing random artifacts, but I am unable to run my game's client because "Direct3D acceleration has been disabled" as the message says.
I have never flashed this card to the 9600 Pro (which I've been told can be done) and I've only tried overclocking it way back when the system was brand new (around this time in 2005). Any OCing through the ATi utility would cause my card to artifact. I thus deleted the utility and have been problem free... up until the past two weeks. If I did indeed flash it to a 9600 Pro, would this rid me of my problems?
THANK YOU FOR READING MY LONG POST (unless you skipped to this bold line ).
I'm afraid my AGP card may be dying and it's not time to upgrade (yet). I am afraid I may need to get a new AGP card because this one is slowly croaking, 1 artifact at a time.
