- Nov 24, 2011
Hi,
I'd like to know if the parts I've chosen fit together and that there isn't anything extremely important I'm forgetting to add-up.
Please check out my build and let me know.
P.S. A video card will be added in the future when I'll be able to afford a good one, as well as a storage device of HDD type. I have my own DVD writer/reader so I don't get a new one.
My parts:
- Coolermaster Elite 430 Black, With Side Window with Coolermaster Elite 500W PSU
---> The cheapest I could find that has a nice count of fans inside.
- Asus P8Z68-V/GEN3, Intel Z68, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0 (x16), D-Sub/DVI-D/HDMI, ATX
---> Took something gen3 so that I'll be able to upgrade it in the future.
- Intel Core i7 2700K, S 1155, Sandy Bridge, Quad Core 3.5GHz, 8MB Cache, HD 3000 IGP 850MHz, 95W, Retail.
- 8GB (2x4GB) Corsair DDR3 Vengeance Racing Red, PC3-12800 (1600), Non-ECC, CAS 9-9-9-24, XMP, 1.5V
---> The cheapest ones, I don't care much about the colors.
- 120GB OCZ Technology Vertex 3, 2.5" SATA 6Gb/s Sandforce SSD, Read 550MB/s, Write 500MB/s, 85K IOPS
---> For fast access and better performance, I have an extra 128GB 5400 2.5" HDD from my old laptop that I'll add up and that's enough for me for now. P.S. Can it be used as single storage device?
- Edimax EW-7612PIn 300Mbps Wireless 802.11 b/g/n PCI Express Adapter
---> for wifi access.
- Colors IT ACT KB-8108 Multimedia Office Pro Keyboard, Silver/Black with MIC/Speakers SKYPE Ready
---> just the cheapest one I could find.
- CM Choiix Cruizer White Wireless 2.4GHz Blue Trace Mouse & Pad 3 Button with Scroll Wheel 1600dpi
---> seems like a decent cheap one.
- 24" Viewsonic VX2451MHP-LED Slim LED (Backlit) Monitor, 2ms, 300cd/m², 20000000:1, Speakers, White, Full HD (http://www.scan.co.uk/products/24-v...-2ms-300cd-m-200000001-speakers-white-full-hd)
OR
23.6" Acer G245HQbid, LCD Full HD Monitor, HDMI/DVI/VGA, 1920x1080, 2ms, 300cd/m², 80,000:1, Black (http://www.scan.co.uk/product.aspx?productid=49576)
---> Whats the most important thing in a screen?! ms, contrast ratio (xxxx:1) how do you choose the one with the best quality? and will I be able to take a 24" monitor on a flight as a hand-luggage?!
- Coolermaster Hyper 212 EVO, 4 Heat Pipes Direct Contact, with 120mm Quiet Fan LGA775/1155/1156/1366/
---> Should I add that or can I just use the stock one... I'm not planning on overclocking the cpu.
- 120mm Coolermaster SickleFLow Blue LED Quiet Case Fan x3
- 120mm Coolermaster SickleFLow Green LED Quiet Case Fan x1
- 120mm Coolermaster Turbine Master Silent Case Fan High Air Flow x1
--> Do I have to get fans?!
Well... that's all of it for now, I do plan on buying the rest of the parts (HDD, Video-card) when I'll get some more cash...
Thanks a lot in advance.
My parts:
OR
