- Jan 19, 2002
- Groton, CT
Well im getting 3 92mm fans delivered on monday, and I need to get a hole saw. Is a 3-1/2 inch hole saw the right size for a 92mm fan?
Do i need any lubricants when cutting (aluminum case) such as cutting oil? Will WD-40 work?
Also, how should i make the cut? From the inside poking out through the outside, or from the outsid cutting twords the inside?
Thanks for the help
-Iron Hawk
Thanks for the help
-Iron Hawk
