On a 4-pin molex connector ( yes, the ones that go to the drives), you have access to both +12V (Yellow), Its Return (Black), +5V (Red) Its Return (Also Black). Having those two voltages on the same connector is one of the reasons why the +7V trick is so popular. The two voltages are right there for you.
Besides improved case cooling, the blower doubles as the CPU HS fan. You do not use it in conjunction with the HS fan. That's the beauty of this whole design. Get rid of all your case fans and the
CPU fan. "One PC, One Airsource". By the way, when you implement it, you cover up the case fan hole on the rear of the case, so the air travels towards the lower front opening. The bigger that lower front opening, the better.
The whole point of the Cohesive Air aka "Hoot Chute" approach was that having lots of bad air sources is not as good as having one good one. Hence the title, Good Air, Bad Air, Good Fans, Bad Fans...
Here's the link, yet again, in case this has tweaked anyone elses curiousity.
Hoot
