Mike89 said:
Well I'm glad you were in a giving mood dude, cause I sure don't know where I would have found that out. Thanks. I'm new into this water stuff and still trying to decide if I'm going to take the plunge. I am doing a lot of reading on it now, where before I wasn't.
On that rad. What size fittings are on it? (if you're in a giving mood still) heh heh.
Also, this is probably a dumb *** question but could you explain what is the difference between a single and double pass rad? Sounds like the double pass is making two loops between the intake and outtake (a lot more water travel), where the single pass is only making one?
The only dumb question is the one that goes unresearched.
First of all, let me explain the reasoning behind my post. If you go
here and read, especially toward the end of the thread, you'll see what I'm talking about.
That said, I'm glad you're researching singlepass vs. dual pass, and that in itself makes me want to explain, because it means someone is attempting to explore something they do not understand fully.
a singlepass heatercore has an inlet on one side and an outlet across the heatercore on the other side.
a dualpass heatercore has the inlet and outlet ont he same side, and a tank directly across.
so, if you are still visualizing what is going on, a dualpass heatercore has 4 times the flow resistance of a singlepass. (think, twice the length for coolant to travel, and half the width.)
go to procooling.com's forums, check out the sticky on singlepass rads
a word or warning....billa, cathar, and phaetsus, along with others, are tired of seeing the same questions...so read and search before posting.
personally, I was vert tenative about watercooling...I spent about $130, and ended up with a setup that dropped temps about 17C at less noise than my aeroflow HSF.
I'm also a mechanical engineering major, so this is all very interesting to me. read up, and THEN post.
