- Jan 30, 2010
- La Crosse, WI
Went through this today for the heck of it to see how it looked. I must saw it's beautifully done I'm sure a lot of people can and have benefited from this.
Nice Joe, only comment I have is you forgot to mention putting the heatsink compound on the heatsink before putting it on the cpu, otherwise you could have a french fried cpuI did see that there was some on the heatsink and cpu in your post on it.
Oh okay, anything I should watch out for when doing it?
Ground yourself...
Will this still be the same for me building a pc in 2012? Will the parts be all different connectors and stuff? I am also 15 so do you think I will manage with these instructions?thankyou!
Static electricity can kill stuff pretty instantly, so make sure you touch the case every so often to discharge, or ground yourself.
Your best bet for a good answer is to post that in the proper section. How to build a PC, a fairly dead thread, may not yield the traffic you need to get an answer.
To give you a quick answer in the meantime however, I wouldnt go that route, but just buy a USB flash stick instead. They are cheap, have loads of space, and the USB3 ones are much faster than that zip drive.
