- Jan 19, 2009
From TPU ( techpowerup )
I dont know if there is already something like this on OCForum. I decided to do one.
Lets take a look at your CPU box first and find the # we are looking for.
sSpec number in the processor markings. ( CPU top )
Your sticker/CPU can differ, but the number are the same. On newer CPU the # is labeled as "S-SPEC : SLxxx" or something.
Note : Everything is from INTEL website.
Now there are all the Intel CPU since the Pentium D. ( Complain if you want older )
Tip : Press CTRL + F and type in your CPU name
EX: Q9550
Pentium D - S-Spec - Mfg Tech - Stepping
960 - SL9AP - 65 nm - C1
960 - SL9K7 - 65 nm - D0
950 - SL95V - 65 nm - C1
950 - SL94P - 65 nm - B1
950 - SL9K8 - 65 nm - D0
945 - SL9QQ - 65 nm - D0
945 - SL9QB - 65 nm - C1
940 - SL95W - 65 nm - C1
940 - SL94Q - 65 nm - B1
840 - SL8CM - 90 nm - B0
840 - SL88R - 90 nm - A0
935 - SL9QR - 65 nm - D0
830 - SL88S - 90 nm - A0
830 - SL8CN - 90 nm - B0
930 - SL8WR - 65 nm - B1
925 - SL9KA - 65 nm - D0
930 - SL95X - 65 nm - C1
925 - SL9D9 - 65 nm - C1
930 - SL94R - 65 nm - B1
920 - SL94S - 65 nm - B1
820 - SL88T - 90 nm - A0
915 - SL9DA - 65 nm - C1
915 - SL9KB - 65 nm - D0
820 - SL8CP - 90 nm - B0
920 - SL8WS - 65 nm - B1
805 - SL8ZH - 90 nm - B0
Pentium EX - S-Spec - Mfg Tech - Stepping
965 - SL9AN - 65 nm - C1
955 - SL8WM - 65 nm - B1
955 - SL94N - 65 nm - B1
840 - SL8FK - 90 nm - A0
Intel Pentium - S-Spec - Mfg Tech - Stepping
E6300 - SLGU9 - 45 nm - R0
E5400 - SLB9V - 45 nm - R0
E5300 - SLB9U - 45 nm - R0
E5300 - SLGQ6 - 45 nm - R0
E5200 - SLAY7 - 45 nm - M0
E5200 - SLB9T - 45 nm - R0
E2220 - SLA8W - 65 nm - M0
E2200 - SLA8X - 65 nm - M0
E2210 - SLB9R - 45 nm - R0
E2210 - SLB7N - 45 nm - M0
E2180 - SLA8Y - 65 nm - M0
E2160 - SLA8Z - 65 nm - M0
E2160 - SLA9Z - 65 nm - G0
E2160 - SLA3H - 65 nm - L2
E2140 - SLALS - 65 nm - G0
E2140 - SLA3J - 65 nm - L2
E2140 - SLA93 - 65 nm - M0
Core 2 Duo - S-Spec - Mfg Tech - Stepping
E8600 - SLB9L - 45 nm - E0
E8500 - SLAPK - 45 nm - C0
E8500 - SLB9K - 45 nm - E0
E7600 - SLGTD - 45 nm - R0
E6850 - SLA9U - 65 nm - G0
E8400 - SLAPL - 45 nm - C0
E8400 - SLB9J - 45 nm - E0
E7500 - SLB9Z - 45 nm - R0
E8300 - SLAPJ - 45 nm - C0
E7400 - SLGQ8 - 45 nm - R0
E7400 - SLB9Y - 45 nm - R0
E7300 - SLAPB - 45 nm - M0
E6700 - SL9ZF - 65 nm - B2
E6750 - SLA9V - 65 nm - G0
E6700 - SL9S7 - 65 nm - B2
E8190 - SLAQR - 45 nm - C0
E8200 - SLAPP - 45 nm - C0
E7300 - SLB9X - 45 nm - M0
E4700 - SLALT - 65 nm - G0
E7200 - SLAPC - 45 nm - M0
E7200 - SLAVN - 45 nm - M0
E4600 - SLA94 - 65 nm - M0
E6600 - SL9S8 - 65 nm - B2
E6600 - SL9ZL - 65 nm - B2
E6550 - SLA9X - 65 nm - G0
E6540 - SLAA5 - 65 nm - G0
E4500 - SLA95 - 65 nm - M0
E6400 - SL9S9 - 65 nm - B2
E6400 - SL9T9 - 65 nm - L2
E6420 - SLA4T - 65 nm - B2
E6400 - SLA97 - 65 nm - M0
E4400 - SLA98 - 65 nm - M0
E4400 - SLA3F - 65 nm - L2
E6300 - SL9SA - 65 nm - B2
E6320 - SLA4U - 65 nm - B2
E6300 - SL9TA - 65 nm - L2
E4300 - SLA99 - 65 nm - M0
E4300 - SL9TB - 65 nm - L2
Core 2 Quad - S-Spec - Mfg Tech - Stepping
Q9650 - SLB8W - 45 nm - E0
Q9550 - SLB8V - 45 nm - E0
Q9550S - SLGAE - 45 nm - E0
Q9550 - SLAWQ - 45 nm - C1
Q9450 - SLAWR - 45 nm - C1
Q6700 - SLACQ - 65 nm - G0
Q9400 - SLB6B - 45 nm - R0
Q9400S - SLG9U - 45 nm - R0
Q8400S - SLGT7 - 45 nm - R0
Q8400 - SLGT6 - 45 nm - R0
Q9300 - SLAWE - 45 nm - M1
Q8300 - SLB5W - 45 nm - R0
Q6600 - SLACR - 65 nm - G0
Q6600 - SL9UM - 65 nm - B3
Q8200 - SLG9S - 45 nm - R0
Q8200S - SLG9T - 45 nm - R0
Q8200 - SLB5M - 45 nm - M1
Core 2 EX - S-Spec - Mfg Tech - Stepping
QX9770 - SLAWM - 45 nm - C1
QX9775 - SLANY - 45 nm - C0
QX6850 - SLAFN - 65 nm - G0
QX9650 - SLAN3 - 45 nm - C0
QX9650 - SLAWN - 45 nm - C1
QX6800 - SL9UK - 65 nm - B3
X6800 - SL9S5 - 65 nm - B2
QX6800 - SLACP - 65 nm - G0
QX6700 - SL9UL - 65 nm - B3
I7 - S-Spec - Mfg Tech - Stepping
I7-950 - SLBEN - 45 nm - D0
I7-940 - SLBCK - 45 nm - C0
I7-920 - SLBCH - 45 nm - C0
I7-920 - SLBEJ - 45 nm - D0
I7 EX - S-Spec - Mfg Tech - Stepping
I7-975 - SLBEQ - 45 nm - D0
I7-965 - SLBCJ - 45 nm - C0
2009/08/01
No processor design is perfect. The first version of a new microprocessor product is the A-0 step. Later, as improvements are made to the product for functional (bug) fixes or manufacturing improvements, the stepping number will increase.
Generally speaking, minor changes result in an increased number, (that is, A-1 to A-2) while more complex changes result in the letter being changed (that is, A-2 to B-0).
EX: Q9550
2009/08/01
