- Jul 3, 2011
I recently (Within the past month) Bought as Desktop from a guy. I am rather tech savvy but I'm having some issues because I have never dealt with this MOBO.
So anyway, I have been having trouble with the drives. It will not recognize any drive I put in there. The power cables are fine, everything is plugged in. I even tried a different ribbon cable. Any Ideas? Thanks in advance!
I'm currently running:
CPU-Z TXT Report
Binaries
CPU-Z version 1.57.1
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium E5200
Codename Wolfdale
Specification Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
TDP Limit 65 Watts
Core Speed 2499.8 MHz
Multiplier x FSB 12.5 x 200.0 MHz
Rated Bus speed 799.9 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 12.5x
Max VID 1.288 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008006h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Chipset
Northbridge NVIDIA nForce 750i SLI SPP rev. A2
Southbridge NVIDIA nForce 750i SLI MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 400.0 MHz (1:2)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 23
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Wintec Industries (7F61000000000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number AU2G732-800P005
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-12-16 @ 266 MHz
JEDEC #2 5.0-5-5-18-23 @ 400 MHz
JEDEC #3 6.0-5-5-18-23 @ 400 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 2048 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Monitoring
Mainboard Model MB-750I-72P9 (0x000002C0 - 0x504C8720)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71882F
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x541
Config Mode I/O address 0x4E
Config Mode LDN 0x4
Register space LPC, base address = 0x0A00
Hardware Monitors
Hardware monitor Fintek F71882F
Voltage 0 3.33 Volts [0xD0] (+3.3V)
Voltage 1 1.07 Volts [0x86] (CPU VCORE)
Voltage 2 1.47 Volts [0x5C] (VIN2)
Voltage 3 0.79 Volts [0x43] (VIN3)
Voltage 4 5.09 Volts [0x79] (+5V)
Voltage 5 12.14 Volts [0x8A] (+12V)
Voltage 6 1.79 Volts [0x70] (VIN6)
Voltage 7 3.33 Volts [0xD0] (VSB3V)
Voltage 8 3.02 Volts [0xBD] (VBAT)
Temperature 0 28°C (82°F) [0x1C] (TMPIN0)
Temperature 1 35°C (95°F) [0x23] (TMPIN1)
Fan 1 1370 RPM [0x447] (FANIN1)
Fan PWM 0 100 pc [0xFF] (CPU)
Fan PWM 1 100 pc [0xFF] (System Fan 1)
Fan PWM 2 100 pc [0xFF] (System Fan 2)
Fan PWM 3 100 pc [0xFF] (System Fan 3)
F0 00 00 00 00 00 00 37 FF 03 FF FF 00 FF FF FF FF
Hardware monitor NVIDIA NVAPI
Voltage 0 1.20 Volts [0x4B0] (VIN0)
Temperature 0 60°C (140°F) [0x3C] (TMPIN0)
Fan PWM 0 40 pc [0x28] (FANPWMIN0)
DMI
DMI BIOS
vendor American Megatrends Inc.
version V1.4B1
date 02/04/2009
DMI System Information
manufacturer XFX
product MB-750I-72P9
version 1.0
serial To Be Filled By O.E.M.
UUID {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
DMI Baseboard
vendor XFX
model MB-750I-72P9
revision 1.0
serial To be filled by O.E.M.
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer Intel
model Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
clock speed 2500.0 MHz
FSB speed 200.0 MHz
multiplier 12.5x
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A2 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation J2A1 (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J6A1 (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (external)
DMI Port Connector
designation Audio Line Out (external)
DMI Port Connector
designation J6B1 - AUX IN (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation J6B2 - CDIN (internal)
DMI Port Connector
designation J6J2 - PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation J6J1 - SEC IDE (internal)
DMI Port Connector
designation J4J1 - FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation J9H1 - FRONT PNL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation J1B1 - CHASSIS REAR FAN (internal)
DMI Port Connector
designation J2F1 - CPU FAN (internal)
DMI Port Connector
designation J8B4 - FRONT FAN (internal)
DMI Port Connector
designation J9G2 - FNT USB (internal)
DMI Port Connector
designation J6C3 - FP AUD (internal)
DMI Port Connector
designation J9G1 - CONFIG (internal)
DMI Port Connector
designation J8C1 - SCSI LED (internal)
DMI Port Connector
designation J9J2 - INTRUDER (internal)
DMI Port Connector
designation J9G4 - ITP (internal)
DMI Port Connector
designation J2H1 - MAIN POWER (internal)
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type SDRAM
DMI Memory Device
designation DIMM2
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type SDRAM
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTS 250
Revision A2
Codename G92
Technology 65 nm
Memory size 1024 MB
Memory bus width 256 bits
PCI device bus 3 (0x3), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x19DA)
Model ID 0x0615 (0x7103)
Performance Level 0
Core clock 740.0 MHz
Shader clock 1836.0 MHz
Memory clock 1100.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
DirectX Version 11.0
CPU-Z TXT Report
Binaries
Processors
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processor 1 ID = 0
Codename Wolfdale
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
TDP Limit 65 Watts
FID/VID Control yes
Max VID 1.288 V
Thread dumps
CPU Thread 0
APIC ID 0
Type 01008006h
Chipset
Memory Type DDR2
Channels Dual
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Size 2048 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 2048 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Monitoring
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71882F
LPCIO Chip ID 0x541
Config Mode LDN 0x4
Hardware Monitors
DMI
DMI BIOS
version V1.4B1
date 02/04/2009
manufacturer XFX
version 1.0
DMI Baseboard
vendor XFX
model MB-750I-72P9
revision 1.0
DMI Processor
manufacturer Intel
FSB speed 200.0 MHz
multiplier 12.5x
DMI Port Connector
connector PS/2
DMI Port Connector
connector PS/2
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
connector DB-9 male
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
usage System Memory
correction None
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type SDRAM
DMI Memory Device
designation DIMM2
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type SDRAM
Graphics
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Revision A2
Codename G92
Technology 65 nm
Memory size 1024 MB
Performance Level 0
Software
