1. Idle temps arent relevant. Sensors are less accurate at idle than when closer to tjmax.ED, it will depend on the type of filtering your case has. Mine has a mesh on all "windows" and the areas where it intakes were mostly blocked after that last time I posted a photo of dirty radiator, remember? During this time, my PC ran probably couple weeks 24/7 total. By this I mean adding all times when it was On.
I cleaned dusto off fan blades and radiator and now I'm running a few degrees cooler while idling. My fans are standard 12v, so they don't turn off when PC is in idle state, they keep milling, all of them.
Foo! I think skunk sprayed in my backyard. It stinks!
2. I dont have any filters.
3. My fans are on and running whwn the pc is on too... as are most people..
The bottom line is that 24 hours or a weeks worth of run time will not affect temps in any meaningful way unless there are extreme circumstances causing significant buildup.
