How To Setup Boinc
SunRedRX7
Kenmore, NY
We get a lot of questions on how to setup BOINC and run SETI, so heres an attempt at explaining it.
1. Download BOINC and install
Click here to go to BOINC download site
BOINC - Berkeley Open Infrastructure for Network Computing
BOINC is what SETI and the other projects run off of.
2. Create your account for the project that your going to be participating in.
This can be done from the "Create Account" link on each of the following
project pages.
NOTE: If you already have a classic SETI account, you can use this link to activate it
Classic SETI Account Activation, this will then allow your account page to show your classic stats as well.
SETI@home - Look for radio evidence of extraterrestrial life
ClimatePrediction.net - study climate change
Einstein@home - search for gravitational signals coming from pulsars
LHC@home - improve the design of the CERN LHC particle accelerator
Predictor@home - investigate protein-related diseases.
Once you have created an account, an email will be sent to you from the
project with your "Account ID" and the "Project's Url". This long string of
letters and numbers is what the project will use to identify you. NOTE: If
you sign up for multiple projects, you will given a unique Account ID for each
one.
It is recommended that you join more then one project in case an individual
project has downtime you will still be able to obtain work. As long as you
use the same email, and run both projects on at least one computer your
"Cross Project ID" can sync allowing for your credits to be combined to result in a
"BOINC Total".
Here is a link for Overclockers.com's BOINC totals
Under section 5 will explain how you can then divide up your computing
resources to each project.
3. Attach to project.
Now that you have an account ID and project url you can set BOINC up to
start crunching for that project.
Open up BOINC, you can either go to your programs menu and bring it up, or
double click the BOINC icon in the system tray. Now select the "Projects"
tab from the top. Click the "Attach To new project" button. Enter the
information that you received in the email from the project when you
registered into the approriate data blanks, and click OK. BOINC will now
contact the project's websites and retrieve the applications needed for the
project, along with some work units. You can check on the work units from
the WORK tab on the BOINC program.
4. Joining Overclockers.com's BOINC Teams.
Go to the Project's website that you signed up for and are running now.
Click "YOUR ACCOUNT" enter your accound ID and you'll be taken to your
account settings page.
Under "Account statistics" is a setting marked TEAM. Under this setting
select the join team option. Search for our team "Overclockers.com" and it
should bring up an option to join team. You can confirm that you have joined
our team by going back to the "YOUR ACCOUNT" page and you should see
Overclockers.com listed for your team.
5. YOUR ACCOUNT - Preferences
NOTE: Settings will not take effect till BOINC contacts the project and
updates its settings, also settings will propagate from project to project if
one of your computers contains both projects.
You may also setup other setup options called, HOME, SCHOOL, WORK.
Section 6 will explain how to control what computers run which settings.
GENERAL - Most of the settings are self explanatory here, an important
setting to make note of is the "Connect to network about every" days
setting. This controls how much work your computers will cache. If your
participating in just a single project, you'll want a larger cache(+5days) in
case of work outages from server problems or other issues. If you
participate in more then one project you can keep this lower as chances are
you won't run out of work as much as long as at least one of the projects
your running is operational.
PROJECT - Each project will have its own set of preferences for itself.
Resource share is what controls how much you dedicate to each project, this
setting has no effect if your only running on project on a computer.
If you are running two projects it works like this. I set a resource share of
100 for Project A, 200 for Project B, and 300 for Project C. Project A will be
given (100)/(100+200+300)=17%, Project B will get 33%, and Project C will
receive 50%.
There are also settings for modifying the screensaver settings as well here.
6. Your Account - Computers On This Account
NOTE: You'll notice an "IP ADDRESS" listed, this is only visible to you when
your logged in, so you don't have to worry about other people seeing this.
This will provide you with a list of computers you have running the project.
Click the Computer ID to be given more information. If you click the number
next to RESULTS, you can check what work units have been done by the
computer, and their status(Credit granted, pending). If you click the WORK
UNIT ID#, you can get additional information on the work unit regarding who
else is crunching the work unit your doing and how close the unit is to being
validated.
LOCATION, this is where you can deceide which Preferences your individual
computers use, Home, work, or school.
If you need any clarification on any of the information in here, please PM SunRedRX7 and we'll add to this, chances are your not the only one wondering.
Thanks Frank, From talking with stratcatprowlin, it stuck me that all we have in the stickies is how to get "Classic SETI" up and running, meanwhile we want people to run BOINC.
If anyone sees anything that needs to be added or clarified let me know.
nicely put together,
i joined up as well, count one dually xeon over to bionic from FAH. :)
thanks Hels
we've had i think now 3 convert one machine to F@H... a possible 4th... i'm going to keep this one machine 24/7 for BOINC, leave all my others and all new borgs as F@H... i'm keeping this machine BOINC as goodwill to the SETI team here... i am now signed up on Einstein@H and ClimatePrediction@H.... so you'll be getting points from me from both...
Awesome work man :) I'll sticky this in a bit since I don't want to immediatly doom it to never being read (as all stickies are :D).
JigPu
Sweet my first Sticky, and its going to get some time to be read before its ignored forever! ;)
Thanks Frank for the ClimatePrediction Signup, I always consider Climate to be the ultimate backup project. Work units that last 3 weeks on a fast machine, and a year to return them.
To anyone wondering pointwise about climate, with work units taking so long. Credit is granted in "trickles" so you'll be granted credit over the course of doing the work unit, so you won't have to wait till its done.
Tyrinon said:
You beat me to it RX7! I would of had mine out in 2-3 days. Your setup is better anyway. :) Good Job! :D
I have to thank stratcatprowlin to, helping him get the BOINC client and registering for a project helped with figuring out the steps needed to get BOINCing. A lots changed since classic if someone wants to start crunching again.
This Fold/SETI-BOINC exchange programs working out pretty good.
lol I've been crunching BOINC for awhile now. I've just been goin' old school the last couple of weeks, that's all. :) Congrats on the sticky!
Quite an accomplishment!
One i was able to do myself with my Subteams Directory over on the F@H Site.. (now its part of a larger sticky/linkage system... but its still considered a sticky)
Didn't you already made a good Boinc faq for newbies SunRedRX7 some time ago? Wonder why it wasn't sticked back then.
sir_LOIN, the ones I previously did about BOINC went into describing the different projects, this one covers actual installation and setup. What we might also want is a general BOINC FAQ to cover some of the questions that always come up as well. Something that as people ask questions in the General SETI forum, we can then have them appended into the FAQ. One question would be along the lines of "Wheres my credit?"
SunRedRX7 but where is your previous thread that described all the projectsl ( like WU size, deadlines and other things ) Ive been looking for it before. It would be good to have this thread stickyed too, or inserted into this one because it is really useful.
Tada!
http://www.ocforums.com/showthread.php?t=367523
I need to go thru it and make some updates because I'm guessing some stuff has changed.
What would be cool would be to start a thread for each project, then have people list how long it took them to complete a WU(maybe an average of 5) for that project, there machine specs, the applications version number...
