datura3 said:
I don't think which asus 865/875 board you get is that important. The difficulty adjusting the vcore can be done with some simple modding.
No offense, but as someone who worked on one of these rigs pretty extensively for the last 48 hours, the reality is that
there are differences between the boards. Some just have troubles with FSB using this platform. It is a known issue. If you check the
XS Dothan overclocking thread, you will see that most of the successful overclockers are using P4P800-SEs (some are using P4C variants).
BTW, I just picked up a P4P800-SE on ebay this morning.
datura3 said:
The lack of vcore adjustment, CPC turn off, and lack of multi control in bios, can all be fixed with mods and windows tweakers.
The P4P800 and DX boards seem to have trouble clocking over 170-190 FSB range. That's no problem with a 15 multi, but at 10 or 12, the board craps out before you get anywhere near the max of the chip, crippling the FSB. Talk about infuriating.
e.g., 180x15=2700, about the max I can clock this thing. But my system also craps out at ~ 12x185 (2220) and 10x185 (1850). Keep in mind I have booted into Windows at 300FSB using a 2.4c on this board, so it isn't a bad unit.
So no, not all problems can be fixed on all boards using tweakers.
People, do what you want, but my advice is to read the
Dothan @ CT-479 - howto and fixes thread before jumping in. Lots of good info there by people who have actually used these rigs (and yes, some of the XS'ers can be goons and ignore questions, but not all. Some of the gurus are really cool, but they just get besieged with PMs, so they have trouble answering everyone. The people in the
howto and fixes thread are helpful and cool).
BTW, the only reason I started with a P4P800-DX is I already had it.
Jimbob7 said:
water normally gains 100 to 200mhz on northwoods depending on how good your loop is. Vcore changes heat output alot.
K, and having run a 2.4c at 3.4 I am aware of that, but these aren't Northwoods, they are Dothans, which put out 1/3 to 1/4 the watts of a Northy. Yes, on the Dothans, water will help disappate heat a little bit, but not that much over a good copper heatsink (compared to what gains you get on a hot Intel chip).
My point wasn't "don't go water." My point was, "You have a helluva lot more to worry about before you have even bought the rig, like,
which board to get."
