- Aug 9, 2002
- Fort St. John BC Canada
This is kind of a long story, but I'll make this short as I can. I 've probably built 10 or so systems in the last year all working to this day all AMD based (we all know why). I recently upgraded to an A7N8X Dlx couple o' 256 MB dual channel sticks of 3200 OCZ and a 2800+ (cost me about $800 CDN and some change from NCIX) few months ago. When I got the stuff I was currently in transition between apartments and I was stayin at a friends. So I spent the afternoon guttin my old mobo etc. from my case (A7A266 1800+ @ 140 x 12.5 (board wouldn't let me go past 12.5 and never posted past 140 fsb and any multiplier) ) usin a volcano 7+ with the sensor stuffed right close to the base of the heatsink... oh sorry I'm goin on... anyways so back to my guttin show. I proceeded to install my new stuff and took care in all the ways necessary to avoid some cataclysmic disaster like shortin her out somehow. Upon initial boot the power seemed to have to build up as the boards (A7N8X) LED would blink and the cpu fan and other fans fluxuated between the on and off states for about 10 to 15 seconds until the board finally beeped, however it would not run past the logo screen. I'm tryin to make this short... I had never seen this in 8 yrs, power goin on off on off on on off on on on off ON! you get the idea, I jumped on the power supply as my first perp but it's fan worked fine and the rest of the board just didn't get power... or something. For some reason right at that time my old (300W) PSU decided to retire I guess. Last thing I guy would go after in the process of elimintation when a brand new system is started for first time and it won't boot, even after it's tourettes like power up... a PSU with a functioning history be the last suspect no?. I'm doin all this on my friends kitchen table in his small apartment... anyways there is a point to all this. I made absolutely sure there was nothing contacting the PCB that wasn't supposed to whilst I reseated the ram, installed a new expensive PSU and reseated the CPU and HSF. Right there is where I make my first mistake (complacency) I wouldn't find out till later (little less than 2 months later.) Since then I settled into a place and began usin my computer as normal playin games mostly, readin this and that on the web. I'm the type of guy to have stuff like WCPUID and Regclean and just apps or utils that allow a guy more control over his computer than the average "computer store computer" buyin joe, I'm pretty aware of what I can do with my rig. Mistake number two (ignorance) was not knowing that the ASUS Probe utility does not actually give you the temp of your CPU but the ZIF socket it sits in. So I was getting a 21 deg C mobo and 43 deg C CPU reading frome ASUS Probe 2.19. Great everything is perfect I thought... just right. Months pass. Upon doin some readin I happened upon a post from a guy and I ended up at MBM 5 site. I though wtf I'll check her out, besides I just updated to latest bios. MBM 5 is pretty comprehensive and I was, and still am pretty impressed at it's overall functionality, everyone should know this stuff, you got big dials in your car for temps and whatnot, same thing pretty much no? What's a 70 yrs old lady gonna do when a dial on her dash is in the red? pop the hood? not my gramma. Point is temp dials are there for a reason, and it would serve us all to know if the rig is runnin hot for some reason or other... (*cloot <----- SLAPS ASUS*) Anyways so I configured MBM 5 so that the CPU temp guage was actually reading temps from the diode on chip. Sit down if your readin this while makin your health drink, mobo was 23 deg C, CPU was 76 deg C, 76 blistering degrees at idle... not f'n kidding at all. I was obviously shocked to say the least. When I build a new system I try to familiarize myself with the bios and in my own rig's case I was well aware of what I was doing in the bios. When I initially built my system I immediatley changed my stock barton 2800+ 333 FSB to run at 400 fsb as I know it's quite capable of this even with stock cooling... usually, (ram was at 100% or same spd as fsb). Now I was at 76 degrees celcius at idle with my head in my hends. I made triple sure that MBM 5 was reading correctly as I made my brother an identical system and MBM 5 showed a 50 deg C idle and 58 deg C load... warm but ok. So back to my machine, I said heck with it and ran prime 95 torture test with MBM 5 runnin and the temp soared to 84 deg C yes that's not a typo 84 degrees... hold... hahahahahahahahaha arrrrgggh. Keep in mind for nearly two months I had been playin games like Battlefield and Unreal 2 and MOH etc. games that can strap a DX8 system on an oc'ed board oc'ed vid card and oc'ed ram and 2800+ doin 2.2, CPU must a hovered aound that temp for hours and hours at a time. I let my rig cool down as much as possible before I shut it down and waited about 30 mins before crackin the case the sink was body temp by then. When I removed the Volcano 7(also oc'ed) I saw that the Arctic Silver I used seemed cooked kinda gooey and pasty. I looked on the bottom of the heatsink and I saw that the chip had actually been sitting way off to one side of the copper core on the sink. Yes, way back at my buddies place during all the confusion (my current excuse) I had put my heatsink on backwards so that the bottom of the Volcano 7 which has two elevations, the very bottom of course for the CPU and the slightly higher elevation made room for the housing for the ZIF socket retention mechanism. Yes my heatsink was probably barely touching the Arctic Silver and barely touching the die. I don't know what to say... I just don't know. Anyways this is really a testament to AMD, they make very efficient and very tough CPU's because I have since properly mounted the HSF and now my idle temp is 53 and load is 58 (room tmp is 23 deg C) it's been totally rock solid and I mean it, dead stable for the last couple months since my fiasco. I just can't belive I did that... and the friggin thing is workin great right now at 218 FSB x 10.5 runs any bench and wastes my brothers identical system. Can you belive that... I have to, I did it, f'n moron that I am or was. Anyways hats off to AMD. And if you read this whole thing you poor SOB sorry I had to taint your wonderful day with my sad a$$ antics. Learn from us dummies. That CPU will run hot... HOT
cloot
cloot
