Hi everyone!
What programs are you use to check cpu stability?
Until I used Linx 0.6.5(avx) and prime95 27.9.
These programs are give +100mV under stresstest in adaptive mode.
If i set to override mode the programs are not give +100mV,working on the adjusted Voltage,but sometimes crash or make bsod.
When i use x264 hd encoder i set 1,220-1,225V in BIOS and 4,5Ghz,its works fine under windows from 1,232V to 1,240V.
But if i want to stresstesting with linx or prime i need to give more voltage in bios.
for linx 1,24V its working on 1,256V in windows
for prime i give 1,25V but the program make bsod after 4hours in blend test.
I really dont understand. I can gaming and encoding with 1,24V under load in bios,but not stable in these programs.
I have MSI Z87 G43 board, 4670K cpuwith Noctua NH-D14 ,teamgroup zeus 1600Mhz ram(2x4GB),adata xpg sx900 128G SSD,wdc black 1TB Fzex,bequiet system power 7 400W PSU,asus r7 260X dc2oc 2gb ddr5
Whats wrong?
***I forgot to write: My cpu is deledded(liquid ultra under ihs,arctic mx2 on the ihs) and the higher core temps around 75-80 degrees under linx load.1,256V in windows
