- Jan 25, 2005
- Denver, CO
ok so Im trying to setup a firewall with IP Cop and am starting to get frustrated. Right now I'm trying to just setup a Green + Red setup to test it. I think Eventually I need green + orange + red even though the green won't be used.
so here is my setup. I have the red interface set to the onboard NIC...and configured with a static IP. That cable is coming from a campus connection. Then I have a 3comm PCI NIC configured as green with 192.168.1.1 as IP and 255.255.255.0 as mask. and that cable is going into a hub. then I have my computer plugged into the hub and am I have tried setting my machine to DHCP and to a 192.168.1.x static IP either way I can't ping the firewall at 192.168.1.1 anyone know why?...it seems like it should work.
**edit** ok it works now, I moved green to 192.168.0.1, apparently the hub has some web based options you access on 192.168.1.1
but let me ask for advice. the setup I need is nothing complicated..some additional protection for web servers which I think they can't be on green do to the port translation. So does that mean I need to go green + orange + red and stick the webserevers on orange and put a third NIC in the computer to assign to green and then just not use it? too bad there's no orange + red config.
