My system temp is usually in the 30's (2x 120mm 1600rpm 35cfm), while the CPU is usually in the high 40's- low 50's (Smart fan II @ 3500rpm). Since the CPU is so hot, maybe I put too much or not enough AS3, it was my first time to put a heatsink on after all.
Also if this helps, i can run 166 x 13 perfectly stable with 7-3-3-2, but its 166 x 13 is unstable at 5-2-2-2.
Thanks
Thanks
