- Jul 3, 2001
- Schenectady NY
Is it possible to get work units under 3 hours? My times on the work units seem to be getting faster on each new WU. I just pulled off this morning a WU @ 4hours 9 minutes 6.9secs. I would like to know if the CLC version will allow me to get to 3 hours or less for i'm using the screensaver version. I disable all running software running in my taskbar and all other software exited then i minimize the SETI@home program which is set to run all the time, no screensavers are on , monitor set to blank and then turn off speakers and monitor.
Specs :
P4 1.7 GHZ Not overclocked till i get my waterblock although i've had it at 1869 stock heatsink and fan but ca't run 3d apps without the app shuting down and going to desktop.
ASUS P4T
256 M Samsung RDRAM
2 PSU's (350W + 300W)
2 Seagate 30.6 G Barracudas
Pioneer slot DVD
ASUS V7700 Geforce 2 deluxe
Soundblaster Live w/digital i/o daughter card
Win98
By the way I joined your team for i just started doing WU's last week and can't give you too many WU's without wife bitching this computer is on too much. I'll try to give you 10-15 per week.
Specs :
ASUS P4T
256 M Samsung RDRAM
Pioneer slot DVD
Win98
