Yes there is, you have to have multiple instances of FAH running, you can create 4 seperate folders with the FAH program in each one. Of course the machine will fold 4 times slower, just make sure for each instance, you make the machine ID different, 1 through 4.
Steve, yes and no.. What you have to do is to run multiple instances of the client on each machine & give them different machine IDs. You can run up to 4.. just make sure you start them with the -local switch and have them all in different directories. This should slow down your machine's enough that downtime won't matter all that much unless its extended downtime.
EDIT - /me snaps nikhsub1's doggy snout for answering before him.
