Hi all. I have a Corsair HX850 Professional PSU. Its a lot more than I really need, but I decided to pay up as I know a dodgy power supply can really screw with stability.
Recently my PC has been randomly restarting without BSOD. If I try to restart using the 'Reset' button it normally gives me the beeps telling me my ram is screwed, but I have run MemTest on it several times and the ram seems fine. The only way to restart the machine is to unplug and wait for 20secs, then restart the machine. Looking online, the issues I have sound similar to those with PSU issues, so I looked at my bios to check the voltages. I saw the following:
CPU Voltage - 1.288v
3.3v - 2.896v
5v - 6.033v
12v - 14.104v
These dont look normal - I'd expect the numbers to match the voltage ratings of the rail. Is my PSU all messed in which case I'd be really quite disappointed.
This might be related, but I am not sure. My GPU is also acting up, with fans constantly at 75% - 90% and idle temps at 85c going to 100c under load. This also kicked up in the last few months. Its a standard HIS 6970 which should not (and did not) struggle to run my games. At the moment I get anywhere from 6 - 30 FPS on games like Far Cry 3 on low settings 1920x1280 which is way below what it should be doing (with fans at 100% and 100c).
Thanks in advance.
3.3v - 2.896v
5v - 6.033v
12v - 14.104v
Thanks in advance.
