- Jan 11, 2007
- Managua, Nicaragua
ok, I want to water cool my CPU, Chipset and VGA..... I have the following:
Case: Coolermaster Stacker
cpu: Q6600
mobo: Asus Maximus Formula SE (the water cooled version) (Im geting it next week)
mem: 4gb ocz reapers
vga: MSI 8800 Ultra
I bought about a year ago the Thermaltake Bigwater 735 kit. I have my cpu waterclooled with it. I have the original cpu block and the pump, The reservoir is a swiftech and the radiator is the Dangerden Black Ice Xtreme 2 with the shroud to put my radiator in the bottom of the case. I also have the original radiator but is not in use.
I want to water cooled the CPU, chipset and VGA at the same time.... my question is...
My pump is going to be able to handle it?
is 400LPH and my entire system use 3/8 tubing. I dont want to change to 1/2 right now because I spend almost all my money on the motherboard... (my p5b die last week ) and changing to 1/2 implies new block, pump etc....
If my pump is not able to handle all this can I do the following?:
1) Buy a better pump maybe some 500LPH like the dangerden one... and water cool all my system with it... Also use 2 radiator.. the original from the TT bigwater 735 and the DD Blackice Xtreme 2 ?
2) buy other pump and and make 2 WCS.. One with the bigger radiator and the best pump for the CPU and chipset and the other using the TT pump and radiator alone for the VGA??
the VGA block that Im using is this: http://www.frozencpu.com/products/6...Cooling_Block_RL-VNA-DO11-GP.html?id=uTibuSmA
sorry any type-o as you may notice english is not my primary language
thanks
cpu: Q6600
vga: MSI 8800 Ultra
thanks
