Have you thought about used?
I mean don't downsize the rad etc, if that's what your going to need. Most of my parts are used. Blocks and rads don't usually wear out, even my D5 is used (and I've been running it 24/7 for about a year.) Parts that are up to the task, that may be replaced down the road. (either with new, or a completely new setup)
This is IMO.
FWIW, I just picked up a used D5 vario for about 40 bucks off a large auction site.
Looks solid.
Distilled water and a biocide? Petras PHN Nuke or a ianh silver killcoil?
Screwclamps like you use on a hose. Lowes at Nellis and Cheyanne has them cheap. As does HD at Lamb and Charelston.
why do the biocide come in such a small bottle? Petra'sTech PT Nuke Concentrated Biocide (10mL) or this one
One is a chemical you add to water, it's proven by thousands of worldwide watercollers.
Who cares what's in it. 4 drops into the water and your good. You can wiki the chemicals in it.
The other is a piece of silver that leaches silver ions into the water in time. Nasties can't grow in it.
I would want Yate mediums on a Swiftech rad personally, but I imagine they would do fine, especially if you get 4 and push-pull the rad with those.
Tubing is not working with barbs?didint it?
1/2 OD barbs on 5/8'' OD Tubing»?
Did I screw up there? I thought that the 1/2 OD barb would go into the 7/16 ID tube. It would be a snug fit but would still work right? If I'm wrong please advise on what size tubing I should change to. I have till monday before they ship my order.
