I am with Earthdog on this one: 2 unrelated things that should not have any impact on each other.
Did you redo the operation a few times? To make sure it is not a matter of ambient temp, or just a couple of random temp peaks that occured?
So are each of your individual Core Temps all 5c lower or just your Package Temp?
You may also want to change your LLC off of auto as it seems to be causing your vcore to fluctuate slightly.
Please also can you include a shot of the cpuz main tab and the cpuz memory tab in future screenshots.
No I hadn't I was running out the door sorry. Did just now. Reason I asked is cuz some software reads differently. Have a look at my screenshot I just took of mine. It's weird, my idle package temp is always about 25c higher than my highest core temp but under load it's less than 10c higher.
let me guess, you got higher temus on the second run when you raised your voltage to stock? The testing method as explained is a bit flawed. You should test longer, and you should also give more time between runs to allow the cooler to go back to ambient/idle temps. It's either that or its changing other voltages. VDIMM by itself does not do this.Yes i did try it different times in different ambient conditions. Ambient temperature cant wary this much during 10 min of testing. All i did change values stress for 3 min change values stress for 3 min. You dont need long stress to see this huge difference between temperatures
Only thing I can see that may possibly have something to do with it is that your timings seem pretty relaxed. I run mine at 16-16-16-36 for 3333MHz. And I know more aggressive timings usually take more voltage. Maybe because you ram is running God Awfully slow it's having an impact. I doubt you'll be able to touch on what's really happening though. Then again keep up the good work. I don't let XTU anywhere near my OS personally, I think it's garbage.
How about some screenshots of your bios settings?
^ As you know better, I wonder why you came here to ask...
