Mobile Barton Results Listing
felinusz
Senior Overclocking Magus
Taiwan
THE MOBILE BARTON STEPPINGS AND RESULTS LIST
PLEASE TRY AND TEST YOUR OVERCLOCK FOR STABILITY USING PRIME95 AND 3DMARK2K1 - AN UNSTABLE OVERCLOCK IS NO GOOD TO ANYONE; LEAST OF ALL YOU!
I would like to thank Rabbi, and UNhooked from the AMDMB forums for allowing me to add the results from their similar Mobile 2400+/2500+ thread to this list as well - good work guys! Their thread on the AMDMB forums can be found HERE.
This thread has been created for the sole purpose of listing the Mobile Barton results. The original post, in the Mobile Barton thread, had become too large for further updates to be added. As such, this thread has been created.
LIST OF REPORTED MOBILE BARTON 2400+ STEPPINGS
AQYHA 0402 MPM (1)
IQYHA 0402 TPMW (2)
IQYHA 0350 MPMW (2)
FJQ4C AQYHA 0350 TPMW (1)
IQZFA 0348 TPMW (2)
IQZFA 0347 XPMY (1)
IQYHA 0346 MPM (3)
AQZFA 0344 SPMW (1)
AQYFA 0343 WPFW (1)
AQYFA 0343 WPMW (1)
AGYFA 0343 MPMW (1)
AQYFA 0343 MPM (1)
AQYFA 0343 WPMW (4)
IQYHA 0343 MPM (1)
AQXEA 0323 MPMW (3)
MOBILE BARTON 2400+ REPORTED RESULTS LIST
(A
* marking means Prime95 stability has been reported)
The pink FJQ4C tag represents a processor with a 1.35 Volt stock Vcore voltage. These are prone to outperforming 1.45V chips, by virtue of their ability to run stably at stock speed with less voltage.
AQYHA 0402 MPM
(Southpaw)
2255 Mhz at 1.6 volts
IQYHA 0402 TPMW
(Air, RedDawg41) (2 chips, results of one below)
(SLK 900U, Vantec Tornado)
2663 MHz at 1.97 volts
IQYHA 0350 MPMW
(Water, ChillPhatCat) (Mag3, Maze 4, Caprice core)
* 2630 MHz at 1.925 volts. 38C load, 30C idle
2500 MHz at 1.75 volts
IQYHA 0350 MPMW
(Air, Richard) (Silent Tt Air)
* 2357 MHz at 1.75 volts, 56C load.
(Sommer)
2473 MHz at 1.6 volts
IQZFA 0348 TPMW
(Air, SlicedBread)
2400MHz at 1.7 volts
IQZFA 0348 TPMW
(Air, Rancherlee)
2172MHz at 1.6 volts
IQZFA 0347 XPMY
(Air, djspl)
* 2355MHz at 1.75 volts. 48C idle, 50C load
* 2400MHz at 1.825 volts. 55C Load
IQYHA 0346 MPM
(Air, hudson_hawk)
2219MHz at 1.5 volts. 41C Load
2240MHz at 1.6 volts. 43C Load
IQYHA 0346 MPM
(Air, Evil_Spork)
10.5x252 = 2652MHz , 2.0v
11x243 = 2679MHz , 2.0v
IQYHA 0346 MPM
(Water, Aldamon) (TC-4, Chevvy Core, Via 1300, Custom Rez)
* 2510 MHz at 1.85 Vcore
AQZFA 0344 SPMW
(Air, NvMatrix)
2200MHz at 1.55 volts. 28C idle, 34C load
2300MHz at 1.6 volts. 31C idle, 36C load
2400MHz at 1.7 volts. 35C idle, 39C load
2500MHz at 1.8 volts. 39C idle, 48.5C load
2600MHz at 1.97 volts. 45.5C idle, 53.5C load
2700MHz at 2.23 volts, doesn't load windows
* 2480MHz at 1.9 volts. 40C idle, 52C load
AQYFA 0343 WPFW
(Air, hitechjb1) (Thermalright SLK-947U , 80mm Tornado/Tt SF II)
2790 MHz at 2.2 volts (80mm Tornado)
* 2650 Mhz at 2.2 volts, 47C load (Tt SF II)
AQYFA 0343 MPM
(Air, Penti) (Thermalright CB-7, 80mm fan)
* 2305 Mhz at 1.8 volts
AGYFA 0343 MPMW
(Air, Nate)
2400MHz
AQYFA 0343 WPMW
(treepop)
2420 MHz at 1.75 volts
2530 MHz at 1.9 volts
2640 MHz at 2.05 volts
AQYFA 0343 WPMW
(Jarhead7236)
2460 MHz at 1.875 volts
AQYFA 0343 WPMW
(OSUmaxx)
* 2500 MHz at 1.825 volts
* 2600 Mhz at 1.95 volts
AQYFA 0343 WPMW
(Air, patrikser) (SLK 700)
* 2400 Mhz at 1.75 volts
IQYHA 0343 MPM
(Water, Vengance_01) (White Water, Caprice Core, Quite One Pump)
* 2500 MHz at 1.875 volts
* 2570 MHz at 2 volts
* 2650 MHz at 2 volts
AQXEA 0323 MPMW
(Air, cartmanea)
* 2000MHz at 1.55 volts
* 2200MHz at 1.65 volts
* 2400MHz at 1.93 volts
* 2300MHz at 1.825 volts
AQXEA 0323 MPMW
(Rocko)
2100MHz at 1.5 volts
AQXEA 0323 MPMW
(Air, j_lost)
2600MHz at 2.0 volts
LIST OF REPORTED MOBILE BARTON 2500+ STEPPINGS
(XXXX = unreported)
IQYHA 0408 XPMW (2)
IQYHA 0407 VPMW (10)
IQYHA 0402 VPMW (1)
IQYHA 0401 XPMW (1)
IQYHA 0352 MPMW (9)
IQYHA 0351 XPMW (1)
IQYHA 0351 MPMW (5)
AQXEA 0350 XXXX (1)
IQZFA 0349 RPMW (8)
IQYFA 0349 XPEW (5)
IQYHA 0348 SPMW (2)
IQXFA 0348 MPMW (1)
IQYHA 0348 MPMW (1)
IQXFA 0348 XPMW (7)
IQFXA 0348 XPMW (6)
IQYHA 0348 XPMW (1)
IQYHA 0347 RPMW (1)
IQYFA 0343 MPMW (20)
AQYFA 0343 MPMW (1)
AQZFA 0340 VPMW (1)
AQZFA 0340 VPAW (1)
AQXEA 0335 XXXX (1)
AQXFA 0335 XXXX (1)
UNKNOWN (CHIP INSTALLED) (1)
MOBILE BARTON 2500+ REPORTED RESULTS LIST
(A
[B[IQYHA 0408 XPMW[/B]
(musk)
2500 MHz at 1.88 volts
(Nismo)
No detailed results yet
IQYHA 0407 VPMW
(Air, peaboy) (Volcano 7+)
* 1992 MHz at 1.5 volts
IQYHA 0407 VPMW
(THunDA)
* 2530 MHz at 1.725 volts. Idle 35C
* 2310 MHz at 1.55 volts
IQYHA 0407 VPMW
(FatesWarning)
* 2508 MHz at 1.8 volts
IQYHA 0407 VPMW
(Air, Hughhefnar) (Thermalright SP-97, 92mm Tornado)
2531 MHz @ 1.8 volts
2600 MHz @ 1.9 volts
2725 Mhz, 46.5C load
IQYHA 0407 VPMW
(Water, mata2974)
(Koolance system, Swiftech MCW 5002, Mag5, two heatercores)
2802 MHz at 2.05 volts
IQYHA 0407 VPMW
(Air, thegame) (SP-97, 80mm Vantec Tornado)
2640 MHz
IQYHA 0407 VPMW
(Water, madsam) (DTEK TC-4, Chevvy core, Eheim 1250)
* 2750 MHz at 2.05 volts
IQYHA 0407 VPMW
(-=Ambush=-)
IQYHA 0407 VPMW
(Water, Dirtybird80) (RBX block, BIX radiator)
IQYHA 0407 VPMW
(Air, Tazman2) (SLK 900A, 92mm Tornado)
2600 Mhz at 1.85 volts
IQYHA 0407 VPMW
(Air, fishtanke) (thermalright SP-97, 92mm Panaflo H1A)
* 2675 MHz at 1.9 volts
* 2714 MHz at 1.95 volts
IQYHA 0402 VPMW
(Air, madsam) (SLK 800A, Tornado)
* 2525 MHz at 1.95 volts
IQYHA 0401 XPMW
(UjinR)
* 2535 Mhz at 1.7 volts
* 2646 Mhz at 1.85 volts
IQYHA 0352 MPMW
(Air, sauria) (2 chips, results of one below) (SLK 800A, Tt SF II)
* 2600 Mhz at 1.8 volts
* 2534 Mhz at 1.825 volts
IQYHA 0352 MPMW
(Strages)
* 2200 Mhz at 1.5 volts, 34C load
IQYHA 0352 MPMW
(jonspd)
2558 MHz at 1.75 volts, 42C load
IQYHA 0352 MPMW
(Air, namgorf) (Thermalright SK7, Tt SF II) (2 chips)
Chip # 1
* 2508 MHz at 1.85 volts
Chip # 2
* 2500 MHz at 1.8 volts
IQYHA 0352 MPMW
(Air, Strages) (Thermalright SP-97, 92mm Tornado)
* 2540 MHz at 1.87 volts, 40C load
IQYHA 0352 MPMW
(IR1)
2420 MHz at 1.7 volts, 40C load
* 2556 MHz at 1.8 volts, 47C load
2620 MHz at 1.8 volts, 42C load
IQYHA 0352 MPMW
(Water, JerMe) (Chevvy core, White Water, Mag 3)
2713 MHz
IQYHA 0351 XPMW
(Air, MitchV) (Tt Silent boost)
* 2500 MHz at 1.75 volts, 49C load
* 2400 MHz at 1.65 volts, 43C load
IQYHA 0351 MPMW
(Air, fanvi) (Tt Silent Boost)
IQYHA 0351 MPMW
(Oni)
IQYHA 0351 MPMW
(Air, 65 Stang)
* 2400 Mhz at 1.7 volts
IQYHA 0351 MPMW
(Air, wrebb) (SLK 900U, 92mm Tornado)
2525 MHz at 1.725 volts
2631 MHz at 1.76 volts
IQYHA 0351 MPMW
(Air, bugeyes) (Spire FR2, 84cfm Sunon)
AQXEA 0350 XXXX
(Air, Poohbear) (SLK800A, 80mm Panaflo U1A)
* 2475 MHz at 1.8 volts
* 2542 MHz at 1.85 volts
AQXEA 0350 XXXX
(RW2112)
2288 MHz at 1.75 volts
IQZFA 0349 RPMW
(login211)
* 2500 Mhz at 1.85 volts
* 2598 Mhz at 2.0 volts
IQZFA 0349 RPMW
(caRpetbomBer)
2200 MHz at 1.5 volts
2400 MHz at 1.8 volts
IQZFA 0349 RPMW
(OTMOPO3OK)
2730 at 2.0 volts, 49C load
* 2680 MHz at 1.89 volts
IQZFA 0349 RPMW
(Captain Hilts)
2500 MHz at 1.89 volts, 58C load
IQZFA 0349 RPMW
(Air, CHiN0)
2200MHz at 1.6 volts
IQZFA 0349 RPMW
(Air, meatneck) (Vantec Aeroflow, TMD fan)
* 2478 MHz at 1.75 volts
IQZFA 0349 RPMW
(Air, musk) (SLK 900U)
2200 MHz at 1.55 volts
IQZFA 0349 RPMW
(Water, Hydr0 styles)
* 2500 MHz at 1.9 volts, 38C load
IQYFA 0349 XPEW
(Water, UNhooked)
2387MHz at 1.8 volts
* 2550 MHz at 2.0 volts
IQYFA 0349 XPEW
(Air, Raybo)
* 2507MHz at 1.9 volts
IQYFA 0349 XPEW
(Air, BaoPee) (Thermalright SLK 900 Air)
2500 MHz at 1.95 volts
IQYFA 0349 XPEW
(Air, thewanted_) (Thermalright SLK 800, Tt SFII)
2300 MHz at 1.775 volts (Heat Issues)
* 2500 Mhz at 1.93 volts
IQYFA 0349 XPEW
2662.5 MHz at 2.025 volts. Idle 39C, Load 46C
~1.9GHz at 1.4 volts
~2.0GHz at 1.5 volts
~2.2GHz at 1.6 volts
~2.3GHz at 1.7 volts
~2.5GHz at 1.9 volts
~2.65GHz at 2.0 volts
2724 MHz at 2.05 Volts (New PSU)
* 2500 Mhz at 1.9 volts
IQXFA 0348 XPMW
(Air, StinkBreff) (Vantec Aeroflow)
* 2400 MHz at 1.725 volts
IQXFA 0348 XPMW
(Water, fLiPaChu)
2000MHz at 1.45v
2310MHz at 1.65v
IQXFA 0348 XPMW
(JDizzle)
* 2205 Mhz at 1.7 volts
IQXFA 0348 XPMW
(kurty)
Cannot clear 2300 MHz (serious PSU voltage issues)
2000 MHz at 2 volts (serious PSU voltage issues)
IQXFA 0348 XPMW
(Air, Turd Furguson) (SLK 900, Delta fan)
2500 MHz at 1.95
IQXFA 0348 XPMW
(Strida)
*2545 MHz at 1.9 volts
IQXFA 0348 XPMW
(Water, Ad Rock) (Custom Swiftech Watercooling)
2525 MHz
IQYHA 0348 SPMW
(G-Diffuser)
2700 Mhz at 1.9 volts
IQYHA 0348 SPMW
(Phase Change, Fushyuguru)
No detailed results yet.
IQXFA 0348 MPMW
(Water, felinusz) (Cascade Block, Dual BIX, Chevvy heatercore, CSL T1 pump)
* 2500 MHz at 1.925 volts, 37C load
Chip has been sold.
IQYHA 0348 MPMW
(Slow Burn)
*2405 MHz at 1.6 volts, 37C load
IQFXA 0348 XPMW
(Water, PotatoMAN) (Whitewater, Dual 120mm core)
2568 MHz at 1.825 volts
2700 MHz at 2.2 volts
IQFXA 0348 XPMW
(goldie)
No detailed results
IQFXA 0348 XPMW
(Air, Posidon42) (Thermalright SK7, Tt SFII)
* 1.836 MHz at 1.35 volts
* 2500 MHz at 1.95 volts
IQFXA 0348 XPMW
(caboob)
No detailed results
IQFXA 0348 XPMW
(sixshot666)
2400 MHz at 1.75 volts
IQFXA 0348 XPMW
(Air, blkgti) (Thermalright SP-97, 92mm Panaflo U1A)
Chip sold on forum classifieds
IQYHA 0348 XPMW
([O-CuK] Marci)
IQYHA 0347 RPMW
(rdw519)
2035 MHz at 1.45 volts
IQYFA 0343 MPMW
(Air, mister694)
2200MHz at 1.575 volts
* 2404MHz at 1.75 volts. 44C idle, 50C load
2530MHz at 1.75 volts
IQYFA 0343 MPMW
(Air, farfromuman)
2500MHz at 1.84 volts
IQYFA 0343 MPMW
(Water, DipStickTony) (Chevvy core, Neomoses Nemesis)
Before burn in:
* 2708 MHz at 1.8 volts. Load 45C
* 2750 MHz at 1.85 volts
2.1 volts on NF7-S will not boot into Windows at 2.8 ghz
After burn in:
* 2700 MHz at 1.65 volts (1.7 in the BIOS, board undervolts Vcore). Load 41C
* 2800 MHz at 1.875 volts (1.95 in the BIOS, board undervolts Vcore). Load ~46C
2950 MHz at 1.95-2.03 volts (2.2 in the BIOS, board undervolts/fluctuates Vcore).
2950 MHz Runs Prime95 Priority Ten for one hour, then crashes.
IQYFA 0343 MPMW
(Air, Water, Molester) (Swiftech Air, White Water, Chevvy Core)
Air:
2712 MHz boots at 2.0 volts
* 2616 MHz at 2.0 volts
* 2652 MHz at 1.97 volts
* 2640 MHz at 1.97 volts, 54C load
(Motherboard fluctuates, and undervolts Vcore)
Water:
* 2678 MHz at 2.03 volts (1.95 actual, board fluctuates Vcore)
IQYFA 0343 MPMW
(Air, Drozdov) (SLK 800A, 92mm tornado)
2630 MHz at 1.9 volts, 44C load
IQYFA 0343 MPMW
(kepten)
* 2841 MHz at 2 volts
IQYFA 0343 MPMW
(Air, Water {PMS}Fishy) (Thermalright SK6, Custom Winflex Waterblock)
Air:
2600 MHz at 1.725 volts.
Water:
2866 MHz at 1.95 volts (2.03 in BIOS, board undervolts), 38C load
More details: HERE
IQYFA 0343 MPMW
(youthemandan)
* 2631 MHz at 1.8 volts
IQYFA 0343 MPMW
(Water, jlin453) (TC4, Chevvy core, Maxijet 1000, really cool custom rez)
* 2740 MHz at 2.0 volts
IQYFA 0343 MPMW
(Water, craneage2001) (RBX, Mag3, Chevvy core)
* 2415 MHz at 1.65 volts.
2700 MHz at 1.9 volts (primes for a half hour)
IQYFA 0343 MPMW
(Prometia, Cow2kie)
* 2760 MHz at ??? volts (preliminary testing with new prommie)
* 2810 MHz at 1.95 volts
2946 MHz Windows screenshot at 2 volts
IQYFA 0343 MPMW
(WinXP)
* 2700 MHz at 1.95 volts
* 2630 MHz at 1.8 volts
IQYFA 0343 MPMW
(adelphia83)
2550 MHz at 1.85 volts
IQYFA 0343 MPMW
(Water, BeerHunter) (DTEK TC-4)
* 2605 MHz at 1.808 volts
IQYFA 0343 MPMW
(Drozdov)
* 2630 MHz at 1.9 volts
IQYFA 0343 MPMW
(Prometia, _TRONIK_)
* 2421 MHz at 2 volts, 48C load (Air cooling)
* 2695 MHz at 1.85 volts, 5C load
* 2828 MHz at 1.975 volts, 5.5C load
IQYFA 0343 MPMW
(Itshondo)
2700 MHz at 2.0 volts, 46C idle
* 2609 at 1.95 volts
IQYFA 0343 MPMW
(Water, Milkman) (White Water, DTEK Procore, Via 1300)
* 2740 MHz at 1.9 volts.
2800 MHz is chip best (so far)
IQYFA 0343 MPMW
(Air, Hellfire) (Thermalright SP-97, 92mm Tornado)
* 2835 MHz at 1.94 volts. Idle 43C, Load 48C.
IQYFA 0343 MPMW
(iLestOne)
* 2595 Mhz at 1.85 volts
AQYFA 0343 MPMW
(Matt Coz)
AQZFA 0340 VPAW
(Air, M4D) (Thermalright SP-97, Tt SF II)
* 2200 MHz at 1.5 volts
2600 MHz at 1.95 volts
AQZFA 0340 VPMW
(Violator)
* 2400 Mhz at 1.725 volts
AQXEA 0335 MPMW
* 2400 MHz at 1.825 volts
AQXFA 0335 XXXX
(Water / Phase-Change, c3ll)
2415MHz
STEPPING UNKNOWN (CHIP INSTALLED)
(Water, Ruiner) (Cascade Watercooled)
* 2385 MHz at 1.9 volts
LIST OF REPORTED MOBILE BARTON 2600+ STEPPINGS
IQYHA 0401 UMPW (1)
IQYHA 0401 UPMW (5)
IQYHA 0348 SPMW (2)
IQYHA 0346 TPMW (3)
IQYHA 0346 MPMW (1)
AQYHA 0346 XPMW (2)
AQYHA 0346 XPW (1)
MOBILE BARTON 2600+ REPORTED RESULTS LIST
(A
IQYHA 0401 UMPW
(Air, Wildcard_QS) (SLK 947U, Tt SFII)
2400 Mhz at 1.625 volts
2605 MHz at 1.8 volts
IQYHA 0401 UPMW
(Water, badge51) (Corsair Hydrocool) (2 chips)
Chip # 1
* 2670 MHz at 2.0 volts, 41C load
Posts 2800 Mhz
Chip # 2
* 2600 MHz at 2.0 volts
Posts 2800 Mhz
IQYHA 0401 UPMW
(gplracer)
* 2508 MHz at 1.7 volts
IQYHA 0401 UPMW
(Air, TheFlons) (AX7, 80mm Tornado)
2616 MHz
IQYHA 0401 UPMW
(Water, crimedog) (RBX, Mag 3)
2683 MHz at 1.85 volts
IQYHA 0401 UPMW
(Air, frodoski) (SLK 900, 92mm fan)
* 2553 MHz at 1.7 volts, 38C load
IQYHA 0348 SPMW
(Larethus)
2640 MHz at 1.88 volts
IQYHA 0348 SPMW
(Air, Timzak) (SLK 900A, Tornado)
* 2410 Mhz at 1.675 volts, 46C load
* 2510 Mhz at 1.775 volts, 52C load
2600 MHz at 1.9 volts
IQYHA 0346 TPMW
(Rabbi)
* 2300 MHz at 1.55 volts
* 2400 MHz at 1.675 volts
IQYHA 0346 TPMW
(Water, d4mon) (Koolance EXOS-AL)
2500 MHz at 1.76 volts, 44C load
2615 MHz at 1.9 volts, 52C load
IQYHA 0346 TPMW
* 2600 MHz at 1.79 volts (board undervolts Vcore), 45C load
IQYHA 0346 TPMW
(Air, marc999) (Thermalright SP-97, 80mm PAnaflo L1A)
* 2400 MHz at 1.625 volts
2500 MHz at 1.7 volts
IQYHA 0346 MPMW
(Water, goldie) (Polarflo Water Block, Eheim 1250)
* 2674 MHz at 1.86 volts
AQYHA 0346 XPMW
(jpm804)
2631 MHz at 1.725 volts
AQYHA 0346 XPMW
(Air, medar) (Thermalright SP-97, Tt SF II)
AQYHA 0346 XPW
(Air, axhed) (SLK-800A, 32cfm fan)
2500 MHz at 1.725 volts
Left blank should more space be needed for updates. First post is for 2400+ chips, second post is for 2500+ chips, third post is for 2600+ chips, this post may be used for 2800+ and 3000+ chips.
PLEASE DO NOT POST IN THIS THREAD
This thread will shortly be linked to the Mobile Barton Weeks, Steppings, and Results thread, please post there :). Thanks!
The entire results list has been updated to mid-way through page 35 of the Mobile Barton weeks, steppings, and results thread. The Original post, in the original thread, had become too long for further results to be added. As such, this new listing thread has been created.
