Dude are you still OCing with that little switch at 166mhz and the Bios .Try putting that back to 133 and OC only from the bios.I remember something about that switch causing some issues
i was thinking of getting this board, but i am not sure if it will do higher that 4.1 on a D0
Sweet its in the main rig now? You got your 1366 bracket?I wanna see benchmarks from the 4850's with this rig compared with your old rig
It not really a budget board.Not exactly sure as this is my first X58 board. So far I find it stable as a rock with zero issues. The NB on it gets a bit hot tho, but adding a 60mm fan on it solved that problem
Clocks extremely well for a budget board. Running 20x200 and ram @ 1600.
