Finally took the plunge and overclocked my PC but, things didn’t go quite to plan. I have been reading around on the Internet for a couple of weeks now about o/c’ing so that I could understand the basics. I also found a cracking setup & tweaking guide for my P4S533 (not sure if I can mention the site so I won’t). Okay, my board has a VEN1 jumper, which gives the CPU an extra 2% of juice. This guide recommends enabling the jumper and going into the bios and setting the vcore manually to 1,575 volts. Great, so I enable the jumper and go into the bios. Erm, only manual settings I have are 1.750/1.775/1.800/1.825/1.850 which confuses me straightaway. Anyway, I put the FSB to 133 and restart and it won’t boot – just brings the bios screen up. I go into Hardware Monitor into the bios and see the vcore is knocking 1.9. I remember that I have seen not to push a P4 over 1.7 so I switch off and take the jumper off. Before I forget, as per this guide I put my memory at 1:1. What I do then is put my fsb to 110, which puts my pci at 37 and reboot. Windows starts up okay and I surf around downloading Prime95/Super Pi/Sandra and install them all. I run the 1M test on Super Pi and all seems ok. I try to run Prime95 and it craps out after 6 minutes. So, I run 3Dmark 2001SE which completes (although my score is less than when I ran it on Sunday with no o/c’ing at all). I try Prime95 again and it craps out after 12 minutes. What I also did this time was to have Asus Probe visible on screen and noticed that my CPU temp was running 50C/122F. This quite concerned me as I have only done a little overclock and didn’t think it would run this high.
I feel really disappointed and downhearted and have put my system back to stock. Has anyone got any hints/tips/advice/help as to what I may have done wrong or what my problems might be?
