That isn't happening because of LLC. That is happening because Small FFT is more stressful and runs CPUs a lot hotter than blend.
Since you are hitting 100C, chances are you are seeing thermal throttling. When running blend, do the clocks drop to 4.7 GHz as well?
What is your actual load voltage? Not what is set in the BIOS, but what does CPUz or Hwinfo or w/e say your load voltage is set at?
If Hwinfo will tell you throttling reasons, or have Intel XTU running with P95 and look to see what it says (at the bottom, may need to expand that space at the bottom to see it all).
Well that's only because I am so good at it!Temps will rise after 20 mins... a couple of reasons...
1. P95 has variable loads
2. It takes at least that amount of time to saturate the loop/reach an equilibrium. Its going to do that with 2x120 or more as well. When testing cusr9m loops, nkrmal heatup periods are, at minimum, 30 minutes for that reason.
You would likely have the first motherboard ever to have automatically set the lowest possible voltage for the clockspeed.
-Rodger
Or, it isnt the lowest voltage.
Also, please note entire post above. Much was added.
I can do that. Are you wanting to see the factory overclock or my overclock? Also, there are different thermal responses to different "full processor" utilizations. I can't even run Prime95 Torture small FFT's with my 5GHz overclock. It will hit a 100 C in just a few seconds and that's too high to play with for me. I can run that however using the factory 5GHz setting. My overclock holds 5 GHz, the factory throttles to 4.7GHz. Best I could do with my overclock is Prime95 Torture Blend setting which will be higher everything most likely then the factory overclock running small FFT's.Post a screenshot of HWiNFO sensor readings under full processor utilization.
The 'factory' overclock should have the -3 avx offset IIRC. So i think there its an offset, not throttling considering your temps dont hit 100c.I can run that however using the factory 5GHz setting. My overclock holds 5 GHz, the factory throttles to 4.7GHz.
