- May 15, 2004
Picked up two very cheap 110W pelts off ebay, basically i got them to play with them and test out making a small AC unit that could fit into two 5.25 drive bays
This is what i found. Pelts are very crap in general.
I did a fair bit of testing last night with a 110W @ 12v made my own little passthrough power connector for it.
And hooked the hot side up to a stock intel cooler with an 80m fan blowing air away from pelt. used AS5 to stick it to HS, and turned it on, ran fine but seriously even a 110W pelt drawing 10 amps or so, doesn't even get cold enough to buildl up ice on the cold side.
I was able to leave it running for ages, like 30 minutes and the cold side was just cold enough to build up condensation, which you could feel when touching it.
What i found amazing, was that the cold side was pretty cold, but the HEatsink was burning up, i recon it was maintaining 35 - 40 degree's the whole stock intel hsf was very hot even after only a few minutes of running.
Without the fan, i couldnt run it for more then 3 - 5 minutes without the cold side starting to warm up.
I then thought ok maybe this HSF setup sucks, so i grabbed my old Hyper 6 and hooked up the fan to it, hooked this up to the pelt, and left cold side bare. Still no ice, bit colder to the touch, Heatsink wasn't as hot cause it can dissipate the heat better.
Step2.
attach heatsinks of various sizes to cold side with a fan, to simulate AC.
Tried with a second intel HS barely even got cold.
Tried with a small intel pentium 233 HSF small copper heatsink with 40m fan in middle. The sink got pretty cold but the air once it gets accellerated seems to lose it coolness and was no better then the fan not attached to the cold sink.
So even without a CPU under the pelt, a 110W tec was producing enough heat to warm up a hyper 6, and not enough coolness to even chill a small heatsink with a 40m fan.
Long story cut short, tec's are extremely innefecient.
I thought a 110W tec would at least build up ice on the cold side, guess i was incorrect.
ambient temps were probably 20-23C in my room.
Step2.
