I would like a definitive answer on why older boards with the same socket don't/can't support Conroe? Is the fixable by a simple VMod?
Hard mods are documented (for the Intel board at least), but they are certainly not "simple". It requires soldering SMTs and given the fact most people can't do a relatively easy Vdroop or Vddr mod without trashing a board, soldering SMTs to the board will be well beyond all except professional circuit board builders/repairers with the right equipment/skills. Might as well buy the correct board (with the right VRM to boot) instead of frying your board trying to make it work and having to buy a new one anyway
Point of the matter is DO NOT BUY A 975 BOARD now and expect it to work with Conroe at all. I'll still be leery after Conroe is released unless the specs specifically say it works with "Core" or whatever they plan to say.
Even brand new 975 boards being released right now are not Conroe-ready. My working theory on this is that manufacturers were originally expecting to have til the end of the year to get Conroe 975 boards ready and probably already had non-Conroe 975s in the works when Intel stepped up the release date. My guess is that they will not offer Conroe-ready boards until the very last second in the hopes of unloading current runs/stock in the meantime. So, I am doubting very much we'll see any 975 Conroe boards before Conroe at all. 965s, maybe a little earlier since they will all be new boards and assuming manufacturers are not behind in production of them since they probably had to "rush".
965 (and presumably new 975) boards will have the ICH8R Southbridge in addition to the VRM 11 package. The ICH8R Southbridge looks like it's supporting a single IDE channel, so start replacing all your PATA drives soon
Some new boards will have digital clock generators (not common/available at all now?). Those *should* achieve a noticeably higher stable OCs than PLL-based clock gens. Some will have more power phases (7-8 instead of 3-4). I am not sure on the 985s yet since there's not a lot of info on them.
Woodcrest (server) will be out in June, Conroe (desktop) in July, Merom (mobile) in August.
Interesting thing about the TDP and the VCore. From what I have seen on xtremesystems, the startup VID is about 1.3V? Can one of you guys with ES chips confirm this? If your ES chips are DTR, then I think we can add 0.2 V to the startup VID to arrive at a rough number.
PS*Can somebody point me to the Intel Tech docs?
I would've bought one 3 weeks ago had there been a board to run it in
There's not much in the way technical documents for Core on Intel's site, definitely no thermal/mechanical specs yet. Those probably won't be out until S-Spec codes are released....or a little before. Most ES's I see are 1.19-1.29 or like 2.6V default, but who knows if CPU-Z is buggy.
