- Dec 27, 2008
- Thread Starter
- #21
the second build is what I would suggest. Get a 4670K...who knows ?? In the future, your daughter might want to overclock the CPU. But if she is planning on using the GTX 580, change the PSU. Nvidia recommends 600W but the PSU you listed is 550W. I wouldn't risk it. By the way, GTX 580 is pretty old and power hungry. You can get a GTX 770 and it'll run cooler, quieter than the GTX 580. Even the power requirements will be a lot less and performance will be a lot more than the GTX 580.
check out the gtx 770 here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500301
Here check out the comparison between GTX 580 and GTX 770 at Anandtech:
http://www.anandtech.com/bench/product/767?vs=829
Something to consider. Thank you. Power estimate needs are usually exaggerated I think by video card manufacturers but they probably need to do that to cover those situations where individuals bought a cheap no name <600W PSU that actually puts out half of its rated power when you are talking continuous power rather than peak power. But a little more wattage margin might be smart. The GTX 580 was given to her so she will be going with that component for the foreseeable future I think.
