- May 9, 2011
- Alberta, Canada
Hi all,
A bit of background, I'm building in a case that doesn't have a front panel (MM U2 UFO) and would like to incorporate one into my build.
I purchased an nMedia panel with Memory Card reader, USB 3.0/2.0, firewire and HD audio, but after reading some horrible reviews online I'm feeling uneasy using it in my build. To add to it, I've upgraded my motherboard to one that's missing an internal firewire header so that port will be useless.
I have one of two options. The first one is finding a PCI card with an internal firewire header and using the nMedia panel (hesitant to do so). The second is the one I'm leaning to, which is finding a new panel with a memory card reader and HD audio. My motherboard came packed with a front USB 3.0 panel so that's covered.
Every site and search engine I've tried either comes up with discontinued/dead links or readers that look absolutely horrendous. There's a Vantec model that comes close, but I would prefer a device with the looks of this Bitfenix panel (which would be perfect but for the lack of HD audio).
Any help or recommendations would be greatly appreciated. Much thanks!
