Here's my system:
Antec 900 Case
Antec TPQ 850W PSU
Asus Crosshair Formula III
AMD Phenom II X4 Deneb 3.4Ghz (965 C3)
Mushkin 996657
Sapphire Radeon HD 5870
2x WD Raptor 1x WD Velociraptor
Windows 7 x64 Professional
I bought a nice cooler that keeps my proc nice and cool, but I can't get a stable OC at 3.9Ghz.... I think I may be missing a setting that might help with my OC. I have gotten some system crashes while testing the stability at 3.9Ghz and the Windows log states that there was a "Memory hierarchy problem" I'm assuming this means something to do with the L3 or L2 cache on the proc.
Voltages are as follows:
vCore - 1.48
CPU/NB - 1.5
DRAM - 1.9
NB - 1.5
SB - 1.2
CPU VDDA - 2.9
I've got the bus speed at 270 with a 14.5 multiplier to get me 3915 mhz, but I keep getting rounding errors in Prime95 after just a few minutes. I have noticed that my vCore seems to be a bit unstable, as it rises to about 1.51 under load, but sometimes it dips back down to 1.49 or 1.48.
I also have the HT link and NB Frequency running at 2700. With my new cooler, the temps haven't gotten above ~46 C, but I haven't been able to really burn in before I start getting errors, so I don't think heat is a problem.
I've read a lot about people hitting 4.0Ghz or higher on air (and way higher on liquid cooling), as long as they can keep temps under control and I'm not seeing any temperature problems in my rig, so I'm hoping I'm missing something that someone else can point out for me so I can get this baby stable at 3.9 or 4 Ghz. If I run the "small FFTs" test in Prime95 (which doesn't test the RAM) I've been stable for 15 minutes (that's where I've stopped it to do the "blend" test). So I'm thinking there's an issue with the memory system. Hopefully someone can help me with this. The memory itself isn't really OC'd. It's supposed to run at 1600mhz, but I've downlocked it to 1440mhz and tightened the timings (which according to Mushkin it should be able to handle).
Thanks in advance for your help.
Antec 900 Case
Antec TPQ 850W PSU
Mushkin 996657
vCore - 1.48
CPU/NB - 1.5
DRAM - 1.9
NB - 1.5
SB - 1.2
CPU VDDA - 2.9
