- May 5, 2004
I'm tired of my case temps being in the 40 - 50 degree margin and decided to buy some bigger and better fans. I have an artec scorpion case that came with a side window fan and two fans in the back of the case (all 80mm)...
My first goal is to take out those two 80mm fans I have in the rear of my case and cut out the sheet metal that acts like a grill...
Picture 1: Pic inside of rear fans
http://www.ocforums.com/attachment.php?attachmentid=33460&stc=1
My problem is that I'm not sure i'll be able to fit a 120mm fan on there...
Picture 2: Pic of rear case fan grills
http://www.ocforums.com/attachment.php?attachmentid=33464&stc=1
This is the fan I plan on adding, two Enermax 120mm fans w/grill..
Picture 2: 120mm Fan
http://www.ocforums.com/attachment.php?attachmentid=33461&stc=1
The other modification i want to do is add another 120mm fan infront of my case. At the moment there is nothing there but four slots for 80mm fans.
Picture 3: Front case showing four 80mm fan grills
http://www.ocforums.com/attachment.php?attachmentid=33462&stc=1
Now that you know what I'm trying to accomplish, here are some questions i'd like answered:
1. What tool should I use to cut off the sheet metal that acts as a "grill" for fans? I hear those case grills are horrible for airflow and since I have a grill on those 120mm fans I figure I don't need that sheet of metal except for mounting the fan.
2. Should I just leave those 2 80mm fans on the rear of my case? I don't think I'll be able to fit a 120mm fan in there without risking damage.
Thanks in advance for any advice, i really appreciate it!!!
