I have a Gateway GT5428 that has these specs:
Processor Intel® Pentium® D 935 (Dual Core) 64-bit processor with EM64T Technology
•Each core operates at 3.20 GHz
•2 × 2 MB L2 cache
•800 MHz front side bus
Chipset Intel 945G
Memory •Installed: 1024 MB DDR2, 533 MHz, (PC4200) dual channel memory (two 512 MB DIMMs)
•Expandable to: 2 GB (two DDR2 DIMM slots)
Add-in Card Slots •One PCI Express ×16 (graphics interface)
•One PCI Express ×1
•Two PCI conventional
Hard Drive 250 GB, 7200 RPM, SATA II hard drive
Support for up to two hard drives
I realize that this is an old machine and that there are far better offerings available,but I am trying to raise a family on a soldiers salary so there is not much left to play with.I would appreciate any input from those in the know.I realize that I will need to upgrade my power supply since it is the stock 300 watt one that came with the machine so I have alredy set aside some money for that.I would like a card that has an hdmi output so that I can hook it to my television that is a 32 inch emerson lcd withh 720p,it was the 250 dollar one at the walmart black friday sale.I would like for the card to be capable of playing h.264,x.264,and mkv files.I also would like for the card to be able to run the dolphin emulator so that I can play gamecube games such as mario kart double dash,and would even like to try wii games if it would handle it.I don't really care about whether its an ati or nvidia card.I can spend between 100-200 on this and would like to have you guys input as I know that this is something that you deal with,and frankly I am just so busy that I almost don't have the time to do the proper research as to how to best spend my 200 dollars to get the desired results,I would like to avoid upgrading the processor to a C2D if at all possible (is it really worth it for what I am doing anyway?),but I am open to adding a stick or two of ram if you guys think that would help.Am I better off with a card that is one or two generations old, but is a higher end card?Or should I be looking at the new generation mid level cards,or is my system going to bottleneck these cards?Any and all help/input is greatly appreciated.Thanks in advance to all that reply.
•2 × 2 MB L2 cache
Chipset Intel 945G
•One PCI Express ×1
