- Sep 29, 2004
No worries mate. I think we've covered all the bases now.
What's the "complete" component list you're leaning towards?
If you're looking to cut prices still further you COULD try looking at a cheaper power supply like the TOPOWER SilentEZ TOP-500SE 500W ATX12V V2.3 Power Supply for $50, just keep in mind that the Seasonic unit suggested earlier is a better unit and will provide more stable voltages, which makes it better in an overclock.
This Topower is the lowest I personally will go choosing a power supply in a build, I recently purchased a Vantec ION2 520W PSU, which is made by Topower. Topower is the OEM for many OCZ and Tagan PSU's. It's a solid budget PSU.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817342016&cm_re=topower-_-17-342-016-_-Product
If you can afford the Seasonic though I urge you to use it instead, especially as this build is centering around a nice overclock. The one thing this Topower unit has over the Seasonic though is that it's modular, which is nice when cutting down on cable clutter. Likewise it's black which may appeal to you if you go for the side window and the price difference is enough for you to actually buy the side window with.
