- Aug 21, 2001
- Milton Keynes, UK
i have noticed that after hoot's article on the four (more like 3 and a 1/2) waterblocks, there has been a large interest in the Gemini waterblock, and also to a lesser extent the [email protected]
The veiw of the majority is that spiral design is a good one which makes blocks like that better then the rest, this is not true. When the designes are consided with the three most improtant factors, flow rate, surface area and turbulance.
The spiral design is starts to look poor, not because it is small, because it does have lots of surface area. But because the design of the channels means the water is constantly turning and has no sharp bends, this mean there is a sever lack of turbulance. The Maze and Swiftech waterblocks do have added turbulance, the maze has it every corner and the swiftech has it everywhere, especially over the core where the water comes in.
I think the main factors here is, as Hoot sugested, the hold down devices. There is nothing wrong with the swiftec hold down devidec, because Swiftech also make heatsinks which have given them the edge over hold down design because the heatsinks they use are very heavy.
I remember when i first made a hold down for my becooling jagged edge waterblock, the temprature was around 28 degrees celcus. when i redesigned the hold down to use rubber washers instead of springs so i could increase the presure, i also added a shim to avoid any breakages.
after that my temprature droped to 24-25 degrees.
If the maze2 had a better, or stiffer hold down then it would have won. it has the largest surface area and also has more turbulance then the Gemini or other spiral designes.
mabey they should be retested with the hold downs at full presure and the cpu with a shim (it will not affect results because all of the waterblocks are using them and the results are only afected when a fan is use because it prevents air cooling the temprature diode)
